Am I asking for problems ?
Old Mar 17, 2010 | 07:38 PM
sam1947's Avatar
I am currently running a Gryphon tuner on level II (87 Perf.). I am seriousley considering replacing an AF1 CAI and replacing it with a AEM Brute Force CAI. The tubes are the same size (3"). Just curious if this will create much of a problem ? TY
Old Mar 17, 2010 | 08:33 PM
shotgunz's Avatar
Are you running canned or custom tunes?
Old Mar 17, 2010 | 09:17 PM
sam1947's Avatar
Custom tunes
Old Mar 17, 2010 | 09:20 PM
shotgunz's Avatar
Then I would post the question on PHP's website.
I don't know enough about the AF1 CAI vs. the AEM Brute Force CAI (and the affect on the MAF readings), but I suspect you will need to get your tunes re-written.
His Excellency MGD may have better in-depth knowledge (it's highly likely actually).
Old Mar 17, 2010 | 09:48 PM
MGDfan's Avatar
Good evening sir!
I would recommend, as Sir Shotgunz wisely indicated, and who is, by the way doing a relentless job of being on my case, to consult with yer tuner wizard.
But - to give you a sense of what is going on here, have a look at this link: http://www.troyerperformance.com/cgi...alogno=2004CAI.
Now, Mike Troyer has tested just about every CAI known to man, 26 at last count, (but likely higher now) and the only two he has found to not require tuning correction - (under normal conditions, as in no pre-existing lean tendency in the stock strategy) - is the Airraid and the AF1 3". The 3.25" and the 3.5" variants both required correction.
Note that AEM is not on that list of two. AF1 and Airaid actually took the time to provide correct geometry at the MAF location to achieve this. Or it was by sheer blind luck, lol.
Eyeballing tubing sizes alone is simply not sufficient.
Unless you are having drone issues or some other problem (sadly they are out of bidness), the AF1 is going to outperform the AEM to a degree. You saw the Airraid's numbers - the AFI was even better. If it's filter replacement only, S&B still makes the actual filter - just fyi.
Long story short (too late, lol) - you are likley going to need a tuning correction to be sure.
Good luck sir!
MGD v4.2
Old Mar 17, 2010 | 10:14 PM
sam1947's Avatar
Originally Posted by MGDfan
Good evening sir!
Good luck sir!
MGD v4.2
Thank you very much for your input kind sir, actually the only reason I was contemplating this move was to get rid of the oiling of the filter, for me that is a royal PITA, otherwise I love the AF1. Is the S&B an oiled element and do you know the part # ??
TIA
Old Mar 17, 2010 | 10:28 PM
MGDfan's Avatar
TIA
Hello again Mr. Sam!
Ahhh ... understood, sir.
Alas - I do not know the specific part number.
You have a couple options:
Look here for S&B specs & match to yer existing filter: http://www.sbfilters.com/Store/Round-w-Flange
Looking at Amsoil, Volant, or AEM websites - they all offer separate dry filters - again match dimensions to existing AF1 filter.
BTW ... here are a couple of excellent, relevant posts related to yer prior intake post you may find helps explain things very well:
https://www.f150online.com/forums/1741424-post17.html
https://www.f150online.com/forums/1743799-post22.html
Good luck!
MGD v4.2
Old Mar 18, 2010 | 06:18 AM
shotgunz's Avatar
Good evening sir!
MGD v4.2
But Dr. MGD, the breadth and depth of your knowledge appears limitless to us mere mortals....
All harassment is intended as a compliment and a thank you for the assistance you provide (and to have a little ).
Or is it too early?
Old Mar 18, 2010 | 06:58 AM
MGDfan's Avatar
Or is it too early?
Top o' the mornin' to you, Sir Shotgunz!
No worries - I know where you are coming from
And thanks, but I really am just another joe with too many hobbies but neither time nor resources to do them all justice. And I read. A lot.
Then there's beer .... and it happened to be green yesterday ... so inevitably it resulted in this:
Too early? Sir - we are blessed with a rotating sphere for a planet, hence the Sun is always over the yardarm ... somewhere
Cheers Sir Shotgunz - have yerself a unstressful day!
MGD v4.2
Old Mar 18, 2010 | 09:15 AM
Both of you are pretty much full of it, and really hard to digest without have had coffee, and I don't even drink coffee.
Old Mar 18, 2010 | 10:19 AM
sam1947's Avatar
LOL I DO drink coffee, but with these two sparing with each other, I think I need something stronger !!
Old Mar 18, 2010 | 12:43 PM
MGDfan's Avatar
Hello!
I'd join you, but I've been seeing things ...
MGD v4.2
Old Mar 18, 2010 | 05:11 PM
shotgunz's Avatar
That right there is funny!
Wonder if I could put 34"s on it?
Old Mar 18, 2010 | 06:24 PM
sam1947's Avatar
Hello!
MGD v4.2
If I saw that stumbling out of a bar, that would be it !!! NO MORE for me : lol:
Old Mar 20, 2010 | 06:46 PM
JackandJanet's Avatar
The pink body panel really enhances the styling, doesn't it?
- Jack
