changing timing on gryphon
Old Aug 2, 2009 | 04:34 PM
not you's Avatar
ok im asking the same question on phps website so i can see the difference in the answers and compare . I was told to bump the timing up on the 93tune and 87 tune but trying to do so and it doesnt seem to work or im doing it wrong . So i figured maybe you guys can help . I go into the 93 tune and say yes to custom tunes. Now i go to timing and slect 1.0 for the timing then hit done and it programs to the pcm (i think it does anyway ) but when i go to back the timing setting it reads 000 . Now is it set or not and if its set does it show in the settings .so if some one can do like a play by play for me so i do not screw things up i would be very thankful Shawn
Old Aug 2, 2009 | 04:41 PM
First, do you really have a 93 tune or do you have the 91 canned tune running 93 gas? If yoiu have a custom 93 tune and 93 gas, you do not bump the timing.
You problem is that once you enter a new setting, it's there. If you go back to settings it will default back to the original program unless you have selected "Save previous settings". So, in effect you are entering it and then erasing it if you are not using the save previous settings.
Old Aug 2, 2009 | 05:34 PM
not you's Avatar
yes i have a 93 tune . i was told by php to bump the timing up on the php forum . so if i have a 93 tune yoursaying NOT to bump timing up correct and i figured it out I set it drove around the block and shut truck off and checked it and the setting was there and it made a big difference but still not sure if i should keep it at 1.0 from what you said before thanks for your info Shawn
Old Aug 2, 2009 | 09:31 PM
If you got a custom tune from PHP that was a 93 tune, Bill would have programmed it for 93 and there should be no need to bump timing. That is what confuses me. Now if it's a 91 tune and youare running 93 octane, yes, you bump 1.00.
Old Aug 2, 2009 | 09:36 PM
PhqChevys's Avatar
I have to 87 towing, 87 performance, and 93 performance tunes in my gryphon. Bill told me that all the timing adjustments are already configured into the tune and not to advance the timing unless the appropriate fuel is in the tank. example- if you have the 91 tune and you fill your tank with 93 then you can advance the timing by 1.0 degrees (.5 degrees for every 1 octane point). Other wise, all the timing advance has already been figured in for you.
Old Aug 3, 2009 | 08:26 PM
not you's Avatar
I spoke to bill threw his web site or forum what ever you want to call it and stated to try bumping timing up . he stated with all types of gas out there he cant get it perfect so try bumping the timing up and i did 1.0 advanced and seen a big difference . but im going to use the 87 tow tune for the next fill up (going to jersey from N carolina) and want to see how it does as far as mpg. i probably wont use the 93 as often as 87 but might consider 89 for awhile when i get back . tell u what go on phps forum and read the one on adjusting timing and see if you read it like i did maybe i was wrong on the advice on the timing thanks for the input Shawn
Old Aug 3, 2009 | 10:47 PM
JackandJanet's Avatar
Shawn - It IS easy to get confused in all the details.
Bill was telling you that quality of gasoline varies between service stations. What works well with your 1.0 degree timing increase if you filled at say, Shell, may not work so well if you filled up at Circle K, even if you filled your tank with 93 octane at both stations!
Different brands of gas DO seem to have performance differences.
Bill told you it was OK to try advancing the timing, a little at a time, until you find the "sweet spot". Once you find it, you're golden. Just don't change brands of gasoline.
The reason Bill said he could not give you a tune to put you in the "sweet spot", is because there are so many gasoline brands. And, he does not have the data for all of them.
- Jack
