Which Scanner to Use???
Old Jun 24, 2009 | 04:55 PM
quebow03's Avatar
Does anyone have a recommendation on a good scanner which will identify the cylinder which is misfiring? Does this require a PCM and Ford software??? I have a cheap OBDII scanner but it only has 2 buttons and won't give me anything but a PXXXX code. Sometimes the codes aren't specific enough.
THANKS!!
Old Jun 24, 2009 | 05:01 PM
i.ride.suzuki's Avatar
THANKS!!
That is all the information you need.
What is the DTC code? We can tell you.
Old Jun 25, 2009 | 12:40 AM
midwestoffroad's Avatar
so your looking with a scan tool with the code informantion also.. there are many that give teh the data and not just a "P" number
Old Jun 25, 2009 | 09:33 AM
inthezone's Avatar
I have a canobd2 scanner /reader reads generic plus oem specific
and freezeframe emissions as well about 200.00can
hooks right to your home pc
Old Jun 25, 2009 | 04:08 PM
quebow03's Avatar
So does this give you real-time info? I have been in the truck with a ford mechanic and he had his laptop set up to see the performance of each cylinder. It was VERY easy to see where the problem was coming from. However, looking on eBay, the PCM and ford software is EXPENSIVE! Just trying to see if their are other alternatives.
Old Jun 25, 2009 | 11:04 PM
FordRacer2005's Avatar
A code scanner and the equipment & software to do what you're talking about are two completely different beasts.
Old Jun 26, 2009 | 01:11 AM
you can get a code reader with live data for 50 bucks and up check auto zone...
Old Jun 26, 2009 | 03:27 PM
So you think that VatoZone and a Code Reader is what the dealer uses?
