sf3 adj options
Old May 16, 2009 | 01:17 PM
gcw's Avatar
gcw
sf3 adj options
i got my troyer tuner fixed now im waiting on my custom tunes but i was wondering on the option menu most of the stuff i understand... but for the ecu gurus out there how do you know what your wot air fuel should be im running a cai and what is the shift press?
ive been experimenting with the data logging and live link software
i know im going to get told if i dont know what it is then dont mess with it but how do you learn?
Old May 16, 2009 | 11:43 PM
Scout19d's Avatar
umm.
if u dont know what it is. do not mess with it!!! j/k i been wondering same thing dude!
Old May 17, 2009 | 12:06 AM
ONELOWF's Avatar
The air / fuel ratio at WOT is a moot point, at the moment. You will need a wide band oxygen sensor to record a/f. You can purchase a WB and connect it to your sf3. Look at the analog inputs 1& 2 in LL, that is where you would read the a/f if you did connect a WB.
The shift pressure controls the firmness of the shifts.....higher pressure = firmer shifts.
the hardest part of Live Link is determining which pids are applicable to your particular vehicle.
