Here's anew one.
I have owned an Edge programmer since 2006. Never had any problems with the unit except if you put the truck in second gear or shift into 4w low lock then it takes you to push the gas pedal half way to the floor before the motor comes off idle. I never use low lock or second on the shifter so it never has mattered. I decided to call Edge today to ask about updating and if it was worth any HP to updated on the internet after 3 years. They seemed to be very helpful but told me I would not gain any power updating but I should send them my Edge programmer and cable plus $50 and they would send me a new one because my hardware is very old.
Do you think this makes sence or should I send in and upgrade to a Gryphon. I want programability, but I also want results that matter when I mash the gas. Thanks Chad |
custom tunes are always better than canned tunes. You will get more for your money with the custom PHP tunes.
Originally Posted by Helrazr
(Post 3715033)
Put the truck back to stock and it does not act this way, it runs normal and throtttle responce is normal.
Alls I know is that when in 2nd on my truck extra throttle is needed to get it going even when it is in stock. At first it seems tight and sluggish but when the throttle hits about 1/4 to 1/2 then it starts to act "normal". This topic was discussed on php's forum. I can not post a link to it at this time. Maybe edge's firmware update may address this or not. Yes, I would take edge up on their offer. Also if you are considering a gryphon then do it instead of the edge.
Go the PHP route, IMHO
Originally Posted by 88racing
(Post 3715236)
Your delima with the throttle response in 2nd gear or in 4x4 low is a built in traction control. Ford does it this way with your transmissions to get you out of slippery situations. So it's like that every time you are doing what you are doing and can not be tuned out. Sorry it's not the edge causing the problem.
Originally Posted by i.ride.suzuki
(Post 3715667)
It is changeable on the tuners end, Driver Demand 4x4 Low. You can have more throttle response. But you are still starting in second gear; 1.55 v. 2.84
(Post 3715693)
So to some degree it is tuner adjustable but not tuner removable? Both in 2nd and in 4x4?
(Post 3715769)
Simply, Driver Demand tables controls the amount of torque available at the 'pedal', this can be increased. But you are still starting in second gear and the TC unlocked.
(Post 3715667)
Originally Posted by onefitty
(Post 3715858)
It is not only this way with the 4x4's. My 2wd is the same way. I use second to pull my boat out of the water because it cuts down on the tire slippage. Truck doesn't respond much until about 1/2 throttle when pulling all that weight up a grade.
This subject was beat to death over in PHP's forum in this thread: http://dygytalworld.ehost-services13...read.php?t=573
88racing asked me to find it and post the link, so here it is. You'll see we went through a rather long discussion with a lot of incorrect statements before we finally arrived at the fact that power seems to be reduced at low Pedal Position/RPM when locked in 2nd gear. - Jack |
(Post 3715942)
(Post 3715942)
| All times are GMT -4. The time now is 06:36 AM. |
