Edge and dead battery
You are not going to believe this, but I bet your battery is still too weak or is damaged. Has enough juice to start the truck, but not enough for the Edge display. I'm assuming that you plug the unit in with the key on.
The Edge DOES NOT LIKE LOW VOLTAGE! And, it has to be initialized with the key ON, engine OFF at a good voltage before it will work properly.
If you have a charger, plug it in. Disconnect the Edge from the OBDII port. Let the charger do it's thing for a while and then, without removing the charger, turn the ignition ON. With the ignition ON and the engine off, the Edge should initialize. Then, you can start your engine and drive your truck to the nearest battery place to replace your battery.
- Jack
You do not need to return to stock before changing a battery. I'd disconnect the Edge from the OBDII port though. Then, once the new battery is in, make sure you have the ignition ON before the Edge is plugged back into the OBDII port.
You don't need to have a charger on the battery to initialize the Edge if you have a healthy battery. A charger just "simulates" a healthy battery if the one you have is weak.
- Jack
- Jack
- Jack
UPDATE. LCD screen is shot. Did all of the above recommendations and still nothing. Sent it back to EDGE. They emailed me saying the screen is shot and they want 50$ to replace it.....
So I checked the Voltage on my battery and it was down to about 11.8v after an hour drive. Battery was still under warranty so I took it back and put in a new one. Edge still didn't display anything. Voltage was at 12v with the new battery so I stuck a charger on it and got it up to 14v. Edge still doesn't display. Looks like I'm going to get a hold of Edge on Monday to send the unit back and try to get a new one.
Sylent, I'm guessing everything was fine with sending the unit back while your truck was still programmed (not to stock). Did you have any problems with Edge or were they pretty quick to take care of your programmer out of warranty? Other than the $50 charge that is. Let me know how it turns out for you.
You have to call Edge an get a return order number. I sent it out there and 4 days later they called to tell me the screen was shot. Its 20 below here in Chicago so thats why they think the LCD is damaged. They fixed it, called for a credit card # for the 50 buck, and it should be here this week.....
