Accuracy Of Edge Performance Testing?
2006 4wd Screw 5.4L, 8" Lift on 35's and 20" wheels, with Magnacharger supercharger
0-60 6.05 Sec
1/8 9.33 @ 76.7 mph
1/4 14.6 @ 93.3 mph
0-60 6.05 Sec
1/8 9.33 @ 76.7 mph
1/4 14.6 @ 93.3 mph
There will always be a 2 mph difference in the Edge readout and the truck speedometer. Ford has that 2 mph built in. But, neither one may be correct. You need to check your Edge with a GPS or do a rollout test to know if it is accurate. What I am saying is that, your Edge could be off by 5 mph and your truck speedo will be reading 2 mph faster than the Edge. Hope that makes sense.
so with a 2001 supercrew 5.4l 2wd stock tires and stock height with a supercharger my times should be much better than yours right
hoping 5 seconds for 0-60 and high 12's low 13's in the 1/4
is that even possible
=bluejay432000;3369838]There will always be a 2 mph difference in the Edge readout and the truck speedometer. Ford has that 2 mph built in. But, neither one may be correct. You need to check your Edge with a GPS or do a rollout test to know if it is accurate. What I am saying is that, your Edge could be off by 5 mph and your truck speedo will be reading 2 mph faster than the Edge. Hope that makes sense.
In my experience though, when the Edge is reading dead accurate, the truck's odometer is also accurate, even though its speedo is 2mph high. So, that's the way I have it set.
Back to the OP's question though, if there is wheel slip, there will be an error.
Consider: Put your truck on ice, floor the trottle and release the brake. The speedo and Edge will read 60mph almost immediately because the wheels will be spinning at that speed. (Wow! Warp factor 4 acceleration)!
And, if you are measuring time to reach 1/4 mile, or 1/4 mile speeds, well, since the PCM sees speed and distance as a function of wheel revolutions, it's going to see a bunch of them on ice in no time at all - again, Warp factor 4.
Yea, I know, we don't do 1/4 mile times on ice, but ANY wheel slip whill give you this kind of error. The speed and time have to be measured from an outside monitor. When does the truck "pass" the 1/4 mile point? How long does it take for the vehicle to be moving at 60mph?
So, if there's no wheelslip, the Edge numbers should be good, otherwise.....
- Jack
Last edited by JackandJanet; Sep 11, 2008 at 10:55 PM. Reason: Added small comment
I know YOU know this, but some may not: Torque can be highly dependent on RPM and to get the best acceleration (passing performance) you need to be in the proper RPM range. A bit like "corner velocity" to a pilot - too fast or too slow and you're dead.
Now, if you use the automotive Torque*RPM/5252 definition, where you can measure the torque, and it's above zero as on a dyno, then you can get all sorts of interesting numbers. And, I'm not sure they really mean much. At really high RPM, you can have very little torque and still have great HP - kind of like on ice. Or, in super low, applying huge torque, but at low RPMs, you can again say you're developing great HP. So what?
So, was Raptor getting 232 hp in your post? Maybe, but what does it mean?
- Jack
