EDGE programmer causing a check engine light...
Old Apr 19, 2008 | 10:34 AM
tjSTX's Avatar
i have had an EDGE evolution programmer that i have run on my 2007 4.6L f150 for a few months now and ever since i have had it my check engine light comes on after a few miles. i have run it programmed on all 3 levels and the light always comes on. if i run the diagnostic it says it is a computer processing error. Is this problem with the programmer or truck? i have taken the programmer off completely and had the dealership i work at run their computer on it and they didnt come up with any trouble codes. What should i try? any help is appreciated.
P.S. How hard is it to trade my EDGE in for a gryphon programmer? all i hear is people saying good things about them on here.
Old Apr 19, 2008 | 12:09 PM
06yz250f's Avatar
id just get rid of the edge. i have an 07 4.6 and it wouldnt run with the edge so i ditched it and probly going to get troyer tunes in the next few weeks or atleast order them.
Old Apr 19, 2008 | 12:10 PM
JackandJanet's Avatar
It DOES sound like your Edge might be the problem. After all, it changes the program in the PCM. And, as I understand your post, if you return the truck to stock (Level 0) you don't get the code? (You can leave the Edge connected at Level 0 - it's just monitoring things).
Have you updated the firmware to the latest version? That COULD fix the problem.
However, if I were you, I'd call Bill at PHP and discuss your problem. If the Edge is at fault, and a firmware update can't fix it, you'd probably want to return it to Edge for a replacement. Others have done this in the past when they've had faulty units.
As far as trading for a Gryphon, assuming your Edge is OK, the process is simple. You just send off your Edge to PHP and for a small fee, you get a Gryphon in return, which is a rebranded Edge that Bill can tune.
Whatever, call Bill first! He'll help.
- Jack
Old Apr 19, 2008 | 12:38 PM
tjSTX's Avatar
thanks for the help. i'll be sure to get in touch with him.
Old Apr 19, 2008 | 03:36 PM
Groovy Chick's Avatar
Former Sponsor
Not hard at all! Give us a call, and we can tell you how the trade-in works.
