edge evo and jet chip module
i have a 2001 5.4l and have a edge evo already installed and mounted and have been using that lately i was wondering is it possible to also add a jet chip module to the computer as well since it plugs into a different spot i think it does correct but is it possible to stack and not tear up anything
Ummmm..... Not a good idea, considering Edge will tune it better than the chip! Besides, if you use them both you run a chance of either
A. Screwing the motor up!
B. Screwing the motor up!
C. All of the above!
Seriously, Once the Edge flashes the ECM, and you stick yet ANOTHER plug in style chip on the box, you have no idea what paramaters the Edge has adjusted, and if the Chip adjust something else... could be bad!
I doin't think it is possible. The edge has to read the stock program. Even if it were possible, I think it could end in disaster.
