Do I need to return to stock before install
Old Feb 28, 2008 | 04:44 PM
jk007's Avatar
Wifey just called, the exhaust system has been delivered... I am going to get it installed over the weekend I hope.
I don't think I need to, but will I have to return my truck back to stock before the install. I have the Edge Evo on Lvl 2 right now... Thanks.
Old Feb 28, 2008 | 04:58 PM
joshmac4.6's Avatar
Don't see any need to, you can if it would make you feel better.
Old Feb 28, 2008 | 05:10 PM
Gotts2BMe's Avatar
no just unhook your battery to reset your computer
Old Feb 28, 2008 | 05:12 PM
ModBargains's Avatar
No need.... just unhook the battery like said before if you want it to "relearn" the new flow.. but you really shouldnt need to do anything
Old Feb 28, 2008 | 05:26 PM
ThumperMX113's Avatar
Unhooking the battery is not going to be needed for an exhaust swap.
Old Feb 28, 2008 | 11:38 PM
jk007's Avatar
Alright, thanks fellas...
Let me ask you this then. Would you recommend unhooking the battery because I have the EDGE on Lvl2 and I'm putting the new exhaust on? What I mean is, will it help it learn the new setup quicker if I disconnect the battery, or does it really matter?
Old Feb 28, 2008 | 11:47 PM
mSaLL150's Avatar
I't doesnt matter.
Old Feb 28, 2008 | 11:51 PM
jk007's Avatar
Originally Posted by mSaLL150
I't doesnt matter.
Old Feb 29, 2008 | 01:32 PM
The exhaust isn't going to make a difference in terms of affecting the programming.
Old Feb 29, 2008 | 05:55 PM
Kevin24's Avatar
jk007 let me know how you like it after the install
Those Magnaflows will get a little louder after some miles.
Remember to put that X-Pipe as close to the last cat as you can!!
Old Feb 29, 2008 | 06:55 PM
i.ride.suzuki's Avatar
I'd like to hear otherwise!
Old Mar 1, 2008 | 10:20 PM
ASEMechanic's Avatar
Disconnecting the battery will force the ECM to go into relearn mode. The ECM will, of course, relarn what it needs to without forcing such a reset, but it just takes a little longer.
On a personal note... Just about any time I work on a vehicle, particularly *UNDER* a vehicle, I disconnect the battery. Just a habit from my mechanic days. The 1/8" deep groove around my ring finger where my wedding ring shorted across 12V to ground is a constant reminder of a moment of laziness and indiscretion. I can still hear my flesh sizzling beneath the red-hot ring as fat in my skin was dripping out. Sorry to be graphic, but I'd rather my example keep someone else from making the same mistake.
Bill
Old Mar 1, 2008 | 10:26 PM
Novakman's Avatar
that had to hurt like a b:tch
Old Mar 1, 2008 | 10:36 PM
Dude, you have no idea! I actually had to use side-cutters and cut my ring off my hand because it melted into my skin and I couldn't get it off. Live and learn.
