Help
Originally Posted by r_mason96
Just took edge out of box made the install turned ignition to on and nothing happend no lights no nothing all fuses good
First things to check would be to make sure that your connections are all seated correctly, then (if just the Edge won't come on) put it back in the box and take it back (ship it back) to where you got it and get another one.
RTFM! (read the f'n manual). The key should be in the "on" position before you connect the Edge to the OBD. The only fuse it would be is the one for the cig lighter/OBD. If that isnt working you are SOL. Double and triple check your connections, and than check them once more.....If that doesnt work than sorry man
