Edge evolution help needed!
Old Dec 24, 2007 | 02:22 PM
wjford's Avatar
Unhappy Edge evolution help needed!
..2007 f150 fx4 with airaid cold air intake
Installed the edge evo level 3, with custom to accommodate stock 20" wheels (2550 tire size) and 3.55 gear ratio.
Start er up, notice the revs stick around 650 then ramp up to 1050 for a second or 2 then levels out and repeats until i put it in gear.
Drive out of the driveway, turn the corner and BAMM!! little wrench shows up on the dash and i hump it home in failsafe mode. evo gives a "P061, unknown" error code.
Put it back to stock and all is cool. tried again and again and found that if i adjust the idle rpm in the custom settings (which, by the way, i cant find any info on what the numbers mean -- im guessing they are in hundreds?!!?) anywhere from +5 to +50, the truck goes like a rocketship, but idles around 1100 rpm while in gear.
Ive seen a thread or 2 similar to this, but nobody seems to have any answers as to what P061 error is (no, its not P0061 or P0601 or P0610).
Anyone have any thoughts??
Ps. I cant seem to find where the utilities and graphs and hp calculator and such are in the fusion software--is it gone since updating from lightning?
Old Dec 24, 2007 | 08:18 PM
grant5127's Avatar
PO61 is a GM cruise-control problem code....
Old Dec 24, 2007 | 09:14 PM
wjford's Avatar
...my point exactly
..perhaps its really P061X -- as in X being the final parameter of the code in the P061's that gives the "unknown" bit
