Tuning for engine mods
Old Dec 20, 2007 | 09:58 PM
Tornadom's Avatar
Hello.
I am looking to add a set of Crane Cams Z-cams Stage II camshafts to my truck (2006 5.4L), as well as the corresponding valve-train upgrades and bolt-on airflow enhancements. I am pretty well set on the S&B intake system and dynatech SuperMAXX longtube headers (with-cats), but not really sure which exhaust sytem will be installed after the headers. My question is with regards to tuning the factory ECU to function properly around the new setup. I know that there are a lot of flash tuners out there that allow for custom tuning, but do they adjust enough parameters to compensate for new camshafts, and longtube headers? What is a good tuning solution for my needs?
Here are things that would be nice to find:
-Ability to tune for my setup (i.e. Cams, headers, etc...)
-Tire-size correction (have 35" tires at the moment)
-Gear ratio correction (4.56 will be replacing 3.55 soon)
-Transmission shift point modification
-Increased rev-limiter (to go with the larger cams and valve-train)
-Ability to display engine vitals in real time (a/f ratio, RPM,etc...)
-Ability to store the factory tune
With all of that out of the way, what else is there? If I left anything out that is important, please let me know and I will update the thread.
Old Dec 21, 2007 | 11:53 AM
i.ride.suzuki's Avatar
Custom tune from a distributor. Or tune yourself with SCT Advantage; but the learning curve is long and you can **** stuff up.
Old Dec 21, 2007 | 05:15 PM
FX4 Matt's Avatar
Registered User
You dont need a tune to run long tubes, as for the cams from what I hear they are not worth the money..... call up Mike at Troyer Performance if you want some great info.
Old Dec 21, 2007 | 05:39 PM
Actually you might, it just depends on how the o2s want to respond.
Old Dec 21, 2007 | 10:09 PM
anaheim_drew's Avatar
Originally Posted by Tornadom
Hello.
Based on your mod plan, you do know that you will not pass smog at registration time.
Old Dec 21, 2007 | 10:43 PM
mSaLL150's Avatar
just FYI, longtube headers, highflow cats, and the S&B intake are ALL illegal in California.
Old Dec 21, 2007 | 10:56 PM
FYI, they are not illegal just not smog complient.
Old Dec 21, 2007 | 11:37 PM
Tornadom's Avatar
They are not carb legal, so by default the truck would fail its visual inspection (regardless of its tailpipe emissions). I already knew about this, (though I appreciate the concern by the members here) and will be working with that when the time comes.
It looks as though the SCT Livewire has the options that I am looking for, and there are a number of places that can custom tune for these parts. Other than the smog legality of the setup, what changes/improvements would you make to it if it were your truck? The intake is up in the air (no pun intended) now that I have done some more reading about the AirForce 1 intakes, and the cams are subject to change as I continue to search for just the right profile. As far as headers are concerned, there seem to be very few options in the way of a long-tube design; and Dynatech has never let me or any of my friends down in the past. The cat-back portion of the exhaust is subject to a lot more research, but will likely end up with Magnaflow components installed.
Thoughts, concerns, comments and geberal discussion:
Old Dec 22, 2007 | 12:00 AM
Cool, just wanted to mention it in case you did not know.
Old Dec 22, 2007 | 12:40 AM
Tornadom's Avatar
Not a problem, I have been in CA my whole life and into cars for just as long. I am new to the forum, but so far the members here seem more eager to look out for one another than on some of the other automotive forums that I frequent. So far, I have yet to be flamed and called a n00b (even though I have thousdands of quality and worth while posts spread out over other forums, and am a global moderartor on a forum) on here. I must say, this site seems a bit more mateur than the others.
Thanks again guys for all of the insight, and for looking out for me.
Old Dec 22, 2007 | 01:16 AM
Not a problem, I have been in CA my whole life and into cars for just as long. I have thousdands of quality and worth while posts spread out over other forums, and am a global moderartor on a forum)
So as a result of time, experience and contacts, the smog situation is not a big deal
Old Dec 22, 2007 | 08:18 PM
mSaLL150's Avatar
if you are worried about smog legality at all, the K&N FIPK air intake system is CARB certified.
