Edge Level 3 Shift Issue?
Does anyone have any issues with shifting? I have been running the lastest updates from Edge without any issues until lately. I have level 3 installed and have only changed the tire size, speed limiter and shift firmness. 1-2 +8, 2-3 +6 and 3-4 +2. Now here is the thing. The truck seems to run fine while just normal driving, the other day i had a youngster in a new Tundra next to me at a light. Light goes green and were off and when the truck shifts from 1st to 2nd my truck looses power and backfires. Is there something up with the Edge and WOT shifts?
There have been a couple people over the last 2 years that have had an issue with the 1-2 shift at WOT. It seems to hit the rev limiter before the shift can complete, causing a bucking sort of issue not unlike your symptoms.
I suggest you go in and set the WOT shift between 5000 and 5150 RPM and set your rev limiter at least 350 RPM higher than your shift, maybe even 400. I wouldn't go much higher than 5600 RPM on the rev. This should eliminate the problem.
Hope this helps.
Bill
Hope this helps.
Bill
