When does Ford reflash?
Old Nov 8, 2007 | 02:36 PM
05supercrew's Avatar
Originally Posted by BlackFX4inTN
I just received an 83$ oil change from the Ford Dealership. I' don't think I will be going back there unless I have some major problems.
Did you get a diesel? How do they justify that? My dealer charges $30 and im in New York they screw every body.
Old Nov 8, 2007 | 04:47 PM
madmaxwell87's Avatar
as a former employee of jiffy lube(only a summer job) dont take it there unless you know the tech working on your truck. ive worked on cars all my life so i knew what i was doing. they mess alot of **** up and its a rip off. only go there if a) you know the tech and/or b) you cant change the oil yourself
Old Nov 8, 2007 | 04:57 PM
Hitched_Gibson's Avatar
Usually that would work, but coming back from Iraq and driving across the country leaves me little option. This is the first time I've ever done any mods to a vehicle and would not like to take the chance on Ford effing up my PCM for me.
Old Nov 8, 2007 | 05:05 PM
I would much rather take a chance on a Ford dealer reflashing than on using a Jiffy Lube. Besides, are you going to have a tuner already? If not, their reflash will only help you. You only worry about a reflash if you have installed some other program other than stock.
Old Nov 8, 2007 | 05:06 PM
Ok, looked back, you do have a custom tune. So just make the service guy write on the ticket, DO NOT TOUCH THE PCM!
Old Nov 8, 2007 | 05:08 PM
One other thing, that Jiffy Lube may not have Motorcraft 5-20 and a Motorcraft filter. That is all I want to use.
Old Nov 9, 2007 | 05:24 PM
They normally will not reflash unless they are dealing with a problem or you have requested a flash. I tell my service manager not to touch my computer without my permission.
Ok, I was kinda skeptical since you were the only one saying this. I called my local Ford Service dept. He confirmed. Justtell tehm not to jack with it.
