Problem with tunes???
Old Oct 15, 2007 | 08:25 PM
  #31
FordScrew24's's Avatar
hey black, yeah i live about an hour away from vmp. I found this out after i had already went with troyer. Do you think they would datalog and dyno it with it being tuned by troyer? Seems like they would try to get you to switch to their tunes.
Old Oct 15, 2007 | 08:41 PM
  #32
MGD, if and when i get this to work, which parameters should i log?
Old Oct 15, 2007 | 08:53 PM
  #33
MGDfan's Avatar
They are listed in the documentation you received with your tuning ( contained in that big *.RAR compressed file you most likley already have) - the document is called 'Datalog Parameters.doc' - it's copyrighted, so I cannot list any content here.
If for some reason you don't have this info, TP will email you another copy.
Old Oct 15, 2007 | 09:00 PM
  #34
yes i do have it on the my computer at home. Im at my parents, using their computer and i couldnt remember which ones to choose.
Old Oct 15, 2007 | 09:11 PM
  #35
MGDfan's Avatar
Well - preparation is a good thing - either print them out or put the stuff on a USB key.
Practice until you are proficient in creating those configuration files ( which you can save - you'll need two).
Make yourself a checklist - as complete as you deem fit, so you know exactly which steps to do and in which order - the dyno session or your own logging session 'on-road' is the last place to be fumbling this - trust me, it'll help reduce any potential anxiety lol.
Good luck.
Old Oct 15, 2007 | 09:24 PM
  #36
BlackDawg's Avatar
FordScrew, if you do end up having to datalog I can't imagine Justin or Mike or any of them caring what or why but them a call. Hopefully you can work it out without having to spend money.
Old Oct 15, 2007 | 09:28 PM
  #37
I think ill just say screw it and give vmp a call so they can do all the datalogging. Im over this whole thing. Even on this computer that has XP, it still doesnt recognize the xcal 2 is hooked up at all. I hope they will work on a truck that isnt tuned by them.
Old Oct 15, 2007 | 09:34 PM
  #38
cdnance's Avatar
i may have just overlooked this, but before you hooked up the USB cable, did you download the USB driver and install it before you plugged it into your computer?? if not then that may be your problem. sometimes if you dont do it in the right order, it wont recognize the info being transmitted.
Old Oct 15, 2007 | 09:37 PM
  #39
i had installed the drivers and livelink from the cd included with the xcal2
Old Oct 15, 2007 | 09:38 PM
  #40
cdnance's Avatar
i just did mine, but i dont remember, does the cd have the USB driver on it??
Old Oct 15, 2007 | 09:43 PM
  #41
MGDfan's Avatar
Always use the latest drivers and software from the SCT site - you don't know how old the CD is....
Give Justin a call & ask about a datalogging session - Mike & Justin are colleagues.
Again - good luck & sorry you could not get the unit to interface - I have done this several times and never had an issue- probably something simple.
Old Oct 15, 2007 | 09:50 PM
  #42
cdnance's Avatar
i may have just found your problem...
you have to download the USB driver. it isn't on the cd. at least it isn't on my cd. you can get it here
http://www.sctflash.com/software/XCal2_Drivers.exe
you have to download this, install it on your computer, then plug in the x-cal2. try that and it should work. sorry about all that. it should work if you can get it to work. you may have to plug the USB cord into another port if you can.
  #43
holy ****, i got it to work. Now i just need to figure out what parameters to log.
Old Oct 15, 2007 | 09:53 PM
  #44
MGDfan's Avatar
I think I already mentioned that - and the fekkin' tutorials
Yep --way back at post #8 lol: https://www.f150online.com/forums/sh...05&postcount=8
Good job, FS24 - don't give up
Old Oct 15, 2007 | 09:56 PM
  #45
Maybe i can get it to work on my own comp with vista now. Also that is the computer with the datalogging tutorials. Thanks guy, you helped me a ton. I really appreciate it.
