superchips
I wouldn't trust that theory. The difference between 91 and 87 is like .20 cents. If your tank was totaly empty it would cost you like 6 bucks more to use the higher octane. The octane booster is at least $3 bucks. Just spend the extra couple of bucks at the pump to be safe or use the lower setting on your programmer. Just my .02
Originally Posted by jsz289
I just got a superchips for my 97 f150 i want to run the 91 octain program can i run it with 87 octain with an octain booster and be safe
Use the octane the tuning requires.
Do you think it was bad for my truck to run it on the lower octane at first even with the higher setting, I only did it till my tank was gone.. then refueled to the higher octane.. No problems. j/w if it was really bad or not??
Just don't do it again, ok?
