Edge and K&N problems
Old Jun 29, 2007 | 04:08 AM
CravinMoorehead's Avatar
I am running the EDGE EVO and a K&N intake, I am having problems with level 1..when I stomp on it the rpms go up but it does not accelerate as it should, and on level 2 at a constant rpm I can hear my intake flutter up and down and watch my tach go up and down 20-30 rpms. It drives me crazy!! If anyone else has had this problem I really need the help because my stock intake tube is cracked and I can not go back to stock untill I find a new tube.
Old Jun 29, 2007 | 07:25 AM
hivoltagefx4's Avatar
Double check all your connections on the Edge as well as your intake. to make sure you don't have any leaks anywhere. I have the exact setup: Edge with a K&N 77 series CAI and not one problem at all. All levels work fine with no issues. I'm very happy with my Edge.
Old Jun 29, 2007 | 03:03 PM
sysman_rick's Avatar
Post
Disconnect the battery neg post.Wait 30 minutes,then reconnect neg cable. This will force the PCM into "learning mode" for your driving habits.
Old Jun 29, 2007 | 11:32 PM
If I disconnect the negative will that effect the EDGE EVO or should I disconnect that also?
Old Jul 3, 2007 | 09:07 AM
05supercrew's Avatar
It will not effect the Evo, just disconnect the battery
