used truck-unkown if tuner used on it. what happens if i use other tuner?
i bought a used 05F150. i dont know if a tuner was used on it before. what happens if i try to use a tuner(i have superchip 1815) on it and it already had tunes and was not put back to stock mode? will the tuner error out or worse, crash the computer?
thanks
victor
thanks
victor
private
Originally Posted by '06STX
Ford can reflash it to stock, then you can put your tuner on. Then your superchips will have the stock setting saved on it just in cas you need to return it to stock. Did you buy it private?
so i need to flash it to stock if it isnt? how would i know its not stock?
thanks for the reply.
victor
