Edge Level 3
Old May 25, 2007 | 10:31 AM
FX4 Adam's Avatar
Edge Level 3
I've been running level 2 for a few weeks now with some custom settings so I am pretty accustomed to how the truck drives and shifts. I filled up with 93 octane, switched to level 3 and loaded my previous adjustments into the system so everything would be correct. It seems like WOT shifts aren't near as harsh now on level 3. I still have the factory belt and on level 2 at WOT the belt would squeal pretty bad (need to buy a gatorback). Anyone else experience this same thing?
Old May 25, 2007 | 10:42 AM
My shift firmness was still about the same. yes, I get the belt squeal on both Level 2 and 3.
Old May 25, 2007 | 11:25 AM
sysman_rick's Avatar
Post
No belt squeal on level 2;nice firm shifts,especially when I punch it.
Old May 25, 2007 | 11:27 AM
C-17 Pilot's Avatar
Since you just loaded Level 3, you've also reset the PCM's adaptive learning. If you give the truck a few days to relearn your driving style, you'll likely notice some changes in the way the truck performs.
Just curious: did you also bump up the timing +1 since you're using 93 octane? Also, what other "previous adjustments" did you make?
Old May 25, 2007 | 12:32 PM
gilsnuxs's Avatar
x2
Old May 25, 2007 | 12:34 PM
Good point on the relearn, I had forgotten about that. takes a few days before it all kicks in. Also a good point on the timing.
Old May 25, 2007 | 12:46 PM
FX4 Adam's Avatar
C-17 Pilot,
Here are the adjustments I have made:
Timing +1
WOT Shift 1-2=5200 2-3=5200 3-4=4800
Shift Firmness 1-2=+4 2-3=+4 3-4=+2
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
Tire Size 2526mm (measured for 285/70/17s)
Hopefully in a few days the weather will clear and the pcm will adapt to the new tune so I can take it out and really see how it is.
Old May 25, 2007 | 12:48 PM
Originally Posted by FX4 Adam
C-17 Pilot,
Timing +1
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
Close to mine, except I have the first 2 shifts at 5250 and I have the pressure at +12.
Old May 25, 2007 | 02:07 PM
C-17 Pilot's Avatar
C-17 Pilot,
Timing +1
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
Have fun! And everyone have a safe and enjoyable Memorial Day weekend!
Old May 26, 2007 | 12:57 AM
FX4 Adam's Avatar
I went back and reselected the level 3 option manually entering in the settings I had posted above, and its definitely running like it should now. I really need a new serpentine belt
Old May 26, 2007 | 10:17 PM
JeremyGSU's Avatar
Anytime I try to do any custom settings on my Edge it goes haywire. I just leave it on stock level 3 and let it along. I wish I could advance my timing and what not but oh well.
Old May 26, 2007 | 10:36 PM
I can't run level 3 without having the dreaded tranny shudder condition, so I run level 2 with 93 octane and adjust the edge settings accordingly.
