After Superchips Install
after 1715 install on my 03 5.4 auto, I left everything "superchips" - no custom tuning, except tire and gear size changes. The 3-4 shift is not right. The truck shifts 1-2 fine, 2-3 fine, then it hangs in 3rd for a few seconds before shifting, then goes to 4th for less than 1 second, then to the low-geared 4th (overdrive?). Other than this, I love the tuner, but what the **** is going on?
https://www.f150online.com/forums/sh...97&postcount=4
Good luck.
Cheers
Bubba
thanks for the reply and the thread, but I've read it, and tried what he says to do there, and I still have the same problem. I switched the 2-3 up 2 marks, and noticed this problem, then switched everything back to superchips and it's still doing it. You think I should go back to the 2-3 change?
Since everyone's truck is slightly different, as an experiment, try going only +1 notch. If it's still the same, try one or two notches the other way (-1 or -2 from the superchips setting).
Be patient and I'm sure you will find a setting that will feel right. I'm assuming it shifts fine stock & there's no underlying problem....
If it persists no matter what you do, try giving Superchips Tech support a call & see what they say. Have your PCM code handy just in case...
Just so you know, 4th is overdrive - what you are likely feeling is the torque converter lock/unlock behaviour, which is driven by load. Feels like a gear change, but isn't. Actually you want it to lockup as soon as possible if the load permits; keeps the tranny cooler.
Good luck!
Cheers
Bubba
Oh ok. So what I should have said at the beginning of this thread is that my truck shifts great stock, but with the chip, the trans goes from 3rd almost immediatly to locked torque converter. Any known way to fix this with the tuner? Thanks, keep up the info, I'm always glad to get awesome info and input on this site.
masoball,basically it shifts into 4th gear then immedietly the converter goes to full lock-up correct?How much gas are you giving it when it does this?If you are barely touching the gas it prob will do what you are describing.Does it do the same if you have your foot into the gas?Is it doing it to the point that your truck actually bogs down?
Ya, just when I give it a small amount of gas. When I'm pushing through gears getting to 50 or 60 mph to go up a hill or on the freeway it doesn't go directly into lockup, just shifts normal until regular lockup point.
Ok after driving for a few days, I now see that if I'm in the middle-to-high rpms in 3rd when approaching 44 mph, it will quickly go from 4th to lockup. After reading enough about the torque converter lockup, I know 44 mph is where it's supposed to happen. So if I give a little more acceleration and keep it steady, I'll pass up that 44mph mark in 3rd, and not get to 4th or lockup til a little later. All is good, and all thanks to you all and this site! Thanks everyone for your past present and future posts and replies!
masonball...I have an 03 5.4L with exact same issue and found this while searching for an answer. Good info, but did you ever change the 3-4 shift points??? I'm currently running the 1715 93 octane tow-performance tune. I haven't modified the stock SCT program...yet.
Originally Posted by liquid 1
Ive got the same tuner 1715 and love it, unless your towing, I would,nt run the tow-perf, run the performance 93 tune, wow its night and day, Im not noticeing the issue mason is haveing..in performance tune the truck seems to have gobs more power, in perf-tow it seems to have more torque..kinda weird how it changes but its a big change..Im only running 93 octane in my rig, and Im loveing it..more miles to the tank..and Ive got 35"ers..3.55 gears..
Hummm, old version, I bought mine back in 2002,2003 and it rocks, I would take it back, sounds like you mighta gotten ripped off..mine has 3 tunes, like most tuners have..stock-87 tune (tow-perf)-performance tune.plus DTC code reader..
DID you call superchip..and did you run a tank of 91 or better trough it before installing the 91 tune..Sorry to here about the problems...keep us posted...
I bought it from the classifieds on this site. I know they're great tuners but it just didn't work well with my truck. I think the price for getting it upgraded would be the same price as getting a new one. Ya, I ran 91. Not saying it's not a good product or that mine doesn't work, just doesn't work well with my truck.
which tuner are you going to get next..
I would give mike troyer a call he might could help you..they say he,s a wizard at tuneing and might be able to repair yours..Im sorry to here the probs..Ive reccomended the superchip to several folks due to the seat of the pants difference its made on my 2001..truck..I hope they dont have the same probs as you have..I was;nt aware of the older versions..
