HELP!!! xcal2
Originally Posted by Marc Carpenter
Chester, you really need to spend more time trying to understand what can and has happened on these boards instead of trying to disprove something you do not believe in....thats why some here treat you like they do....
you just don't listen......I don't know why , I just know it does and I accept that.....Yeah, my truck went into limp mode once too, and it was right after I installed the EDGE. But it wasn't the edge, and it wasn't lean. It was because of wet COP's. And I found out a little while later when I got a code.
Hi Chester;
I'm not calling you out, nor calling you names.
But, Marc's right - you just don't listen.
I think the concept of a transfer function is beyond your grasp. Because if you understood that, half of your misconceptions would disappear.
The link I posted on intakes was germain - I asked you to glean the facts, and the importance of transfer functions were part of that post - sorry you missed the significance and the relevance.
Oh, and the PCM is enormously complex - you got that wrong too. To get all the functionality into so (relatively) few lines of programming is a profound achievement.
Thank God I know one guy who does understand it ! My tuner Maestro!
Cheers
Bubba
PS - Hiya, Dad
Cheers
Bubba
PS - Hiya, Dad
It's also a shame that all these intake companies are selling this product that is apparantly ruining the machines of all who own them, and neglect to purchase a custom tune.
All along, everyone has been saying, "it flows better, so it lets more air in the engine, and it runs lean". And that's crap.
But you're saying that the MAF sensor cannot accurately measure the quantity of air entering the engine, because the tube diameter surrounding the MAF sensor is not the same as stock? Is that right? So you have to modify the programming to account for that?
That's really poor design in my opinion, and I find it hard to believe that they did that. But I don't have one, so I can't go out and measure the diameter. I have to trust you on that!
I still fail to see how the computer wouldn't notice the fact that it was running lean. That one escapes me. And the way Marc's engine knew that it was lean enough to go into limp mode, but STILL neglected to throw a code...
Originally Posted by chester8420
Whatever. Just because it can't accurately read the ammount of air entering the engine doesn't mean it can't set a CEL for a lean condition. I don't know what you're getting at.
Hi Chester.
Okay - let's try this by using an analogy.
Familiar with flowmeters for fluids? Well, for the ones that use physical sensing elements (not the ones that use other non-invasive sensing methods) the sensor sits in a predetermined location inside a venturi of known properties ( cross-section, laminar linearity, flow vs.pressure, etc).
That sensor is not very bright - it knows nothing with regard to it's environment, only that it puts out a signal that changes when the flow changes. That signal, coupled with a transfer function that is based on the physical properties of the tube it's in (and the specific gravity of the fluid being measured), results in a meaningful & accurate representation of the flow. Change one thing, anything, and it's accuracy is gone. A small leak, type of fluid, debris on the element, dynamics of the tube etc, and it cannot be corrected for.
Lesson 1: - the sensor is DUMB. It depends on the engineered characteristics of the tube it's in ( as described solely by the transfer function) to provide useful data.
In a MAF - it's the same principal at work. EXACTLY the same. Change the type of gas (i.e, it's specific gravity) without supplying a modified transfer function for that gas, and it's output is useless, as the MASS of the fluid (a gas is also a fluid, y'know) is different.
- Get the MAF dirty - same problem. It doesn't know it's got caca in it's pants, but the output will be skewed.
- Put the MAF in a different place, in the same tube - same problem.
- Put the MAF in a different tube - same problem.
- Change the dynamics of the gas upstrem of the MAF (e.g. Ram Air) - same problem.
You need a transfer function to account for the deviation or you are toast. The PCM cannot correct, because that sensor is DUMB.
Lesson 2: - the PCM, although complex, is also DUMB in this case - it's only going to provide acurate outputs based upon the accuracy of it's inputs - it does not, in this case, have the sensing or capability to infer that the conditions it cannot possibly sense have changed. Unlike the density of the fluid changing with temperature - it has sensing for that & can correct accordingly.
Now, S&B claims, for example, that they have specifically engineered thier intake's MAF location & tube properties such that the original transfer function that is fixed in the factory PCM will work. The AF1 3" also does not alter the paradigm. But the 3.25" and 3.5" does (as does the JLT) - as has been determined empirically - hence the need for tuning changes. I can't speak to this - the respective experts will need to provide additional input on this state of affairs. If you believe the pundits, it's apparently possible to design it such that no changes are required - I'll rely on the data to support this, speaking for myself, which is why I stated elsewhere that I'd like Mike Troyer to independently test.
Hope this helps.
Oh, and try to watch your manners - I have never told you to 'shut up'.
Ahhh RP, another Windbag response ( damn those solder fumes)
Cheers
Bubba the Winbag
I concur with MGDFan. You also have to take into account costs. It's cheaper to install a MAF that is set to specifically monitor specific airflow parameters than to install an adaptive sensor that accurately measures airflow and air temperature. Warmer air is denser than cooler air, which is why a vehicle running in cooler temperatures runs better than one in warmer temperatures, not to mention heat and other things. An adaptive sensor would allow the ECU to make adjustments for air density, which just plain doesn't happen in the real world.
Chester's theory would be correct if these were adaptive sensors that provided accurate feedback to the ECU so that the ECU could accurately change the fuel mapping. Our trucks, while sophisticated in some regards, are not THAT sophisticated.
Now, take into account the number of F150 owners that play with the performance of their trucks the way we do. That further propagates the fact that the MAF sensor is designed for only one set of parameters. 90% of the trucks sold today will die the same way they came into this world; completely stock.
So, back to the issue at hand. Can you drive your truck with an aftermarket intake kit without doing damage to your truck? Short-term, yes. Long-term, no. Should everyone who installs an aftermarket intake and filter have custom tuning done to correct a lean running state? Yes, of course. Do they? No. Why else would companies like K&N among others have a disclaimer that their product MAY void your vehicle manufacturer's warranty and that installing their product is at your own risk?
Face it, the general public tends not to follow procedures too well. Oil changes, tire rotations, wiper blade changes among other things are things that are far too often overlooked by the general public. How many of the general public follow their maintenance schedule to the letter? Surprisingly few. It would be silly to assume that the general public, in "hopping up" their vehicles would take the time to properly research and do the correct things for their vehicle, let alone read the instructions provided by either the manufacturer of the vehicle or the manufacturer of the aftermarket intake system.
Hi Unclebuck;
A couple corrections, if I may.
Cold air is denser than warm air.
The MAF has the capability to adjust for density change ( = mass change), by the fact that the cooling effect on the MAF hot wire is affected by the Mass (density) of the air flowing past it, Hence the voltage changes reflect the actual Mass of the air, giving you the reason it's named such. There is also an IAT input. Other than that, yup, it's a pretty simple-minded sensor, knowing or caring not a whit about the orifice in which it resides ;-)).
I'll chaulk these up to simple typos
. Happens to me all the time.
Thanks for the support.
Cheers
Bubba
Cheers
Bubba
If I remember right, the computer can detect rapid deviations from the fuel trim corrections table, (maybe 5 or 10%) and recognize those as a malfunction. (such as an intake change) even though they don't surpass the calibration threshold. That's why I suggested removing the battery. By deleting the long term fuel trim corrections table, it gives a greater range of "short term adjustability"...
Yup, grumpy... and dead wrong.....
....If you do write more stuff ( on PCM's, lean conditions, risks, etc), at least make sure it's accurate - I would hate for someone to take it at face value and consequently eff something up. Suggest you consult with MT ( NOT Wikipedia - now there's a pile of smelly doo-doo), to get the facts nailed. Everyone will thank you.
.....glean what you can from this and add the facts to your guide: https://www.f150online.com/forums/sh...18&postcount=5
If you don't wisht to, then perhaps a disclaimer at the top of your guide(s) is in order... to wit:
*** This guide may contain facts, fallacies, hearsay, innuendo, BS, peanuts, animal byproducts, opinions and skewed perceptions - Use at your own Risk !!! ***
..... you remind me of that Faster150 idiot
I will not refute facts. If I'm wrong on anything I said, please correct me, as I am working on old knowledge...
Hi Chester.
OK - I think we should just stop here & agree to disagree.
You are lacking a fundamental piece of conceptual understanding, and it's a hole I've failed to fill.
In a nutshell - the PCM cannot make accurate decisions based upon bad data.
The transfer function is fixed in the pcm - it can only be changed by programming & it is the key to it all - EVERYTHING follows from that. If it no longer represents what the intake looks like, if it is outputting incorrect A/F's, then it's producing bad data, which the PCM still believes to be true, but isn't. There has to be a trusted reference, and that's a big one.
Sorry, but I'm done. Lord knows I've tried. Perhaps the collective brain trust of real experts who frequent here would care to take up the cause. What do I know, anyway?
Me? I'm gonna go solder something - I need a hit of those fumes
Then I'm gonna go out and kill another chebby.
Chester - I wish you well & remember, anything can be taken out of context to twist it into something it's not. You are not an idiot. And 'The Disclaimer' was in the spririt of a joke, nothing more.
Cheers
Bubba the Windbag
Cheers
Bubba the Windbag
I know it may have seemed like argueing to some, but I found it to be very informative. Thanks.
Am I right in assuming that during normal driving the pcm adjust the fuel air mixture accordingly, (assuming all sensors are working properly). Yes?
During WOT, the PCM is set to a particular fuel air mixture that is not adjustable regardless of inputs received from the various sensors. Yes?
Thus the problem with aftermarket intakes is that not only are the sensors not placed properly in the tube (in some cases), but the PCM has not been adjusted accordingly for the increased air flow during WOT. True?
Sorry to drag out the thread, but just trying to make sure I understand what being said here.
We're gonna need Mr. Troyer for this one....
.....if it is outputting incorrect A/F's, then it's producing bad data, which the PCM still believes to be true, but isn't. There has to be a trusted reference, and that's a big one.
We need Mr. Troyer!
well for the most part. even though most will believe that it is not true. i think that all cold air intakes should be able to be installed without having to tune the truck for damage not to occur. if it were true then it should state so on the website or the box. as for the CEL;s. all trucks even though created equal are not. every truck out there even with the same mods is going to run a little different.
Just talk to anyone that races. 2 identical vehicles will perform differently under different conditions. Soooo many variables.
The bad thing is that we read about a few people having trouble with a mod, and myself included, assume that all the mods of that type are bad. could just be bad production, not enough r&d, the altitude, or any number of weather conditions. I'm sure that thousands of intakes have been installed that have not thrown a code. Same with exhaust. some say you lose low end torque, some say not. Again I think it depends on how the vehicle is driven, other mods, tire size, gear ratio, etc. Ya just never know.
But it sure is fun playing around with it.
That's what it's all about.
