Help Will it break
first I ve read this from another post for edge timing
"Roughly 1 degree per 2 octane.
Level 3 (basically 91 octane tune) running 93 = +1 deg.
Level 2 (basically 87 octane tune) running 93 = +3 deg.
Level 3 running 100/101 = +5 deg. (This is for the rich guys!)
These are ideal values at sea level. At altitude, you should be able to add another degree per 2500 ft.
5000 ft. = +2 deg."
I have a 30 gallon tank, If I run 100/101 octane in 5-10 gallons in my truck mixed with 20-25 gallons of 91 octane gas how much would I be able to bump the timing on my edge evo 1.5-2.5 degrees or more?
also when I shift from 2-3 gear floored my belt churps, will it snap eventually, if so will a gatorback belt help?
5000 ft. = +2 deg."
5000 ft. = +2 deg."
5000 ft. = +2 deg."
Last question, yep, and gatorback belt will end the belt squeal.
sweet thanks bro, so a gotorbck belt is just typically stronger than stock and is more durible then stock right, also its an easy install right?
_______________________
2005 F-150 Supercrew 2wd
6 inch Fabtech Lift
Pro Comp 35' All Terrains
4.56 Gears
Flowmaster 40 Series (Muffler Only)
Afe Cold Air Intake
Edge Evo Level 3 Custom Tune
IPod Nano
6 inch Fabtech Lift
4.56 Gears
Afe Cold Air Intake
IPod Nano
