lightning maf
Old Dec 30, 2006 | 04:01 PM
built54's Avatar
lightning maf
Well being at around 325flywheel hp, and a stock MAF, Id like to know if I can put my lightning 90mm MAF on it and if Troyer could tune it to work with my engine...
Old Dec 31, 2006 | 08:37 AM
openclasspro#11's Avatar
i would say that with that crank hp, fuel pump and injectors youi have -yes-imho-phil
Old Dec 31, 2006 | 01:03 PM
built54's Avatar
Well Troyer, please post your input here...
Old Dec 31, 2006 | 02:00 PM
One Ford Truck's Avatar
built,
I'm running a lightning MAF on my '98 with a "lightly modified" 4.6. Mike got it dialed in -- no problem.
enb
Old Dec 31, 2006 | 02:04 PM
built54's Avatar
did you notice any gains?
Old Dec 31, 2006 | 10:20 PM
I can't tell you for sure as I installed headers (what a job that was), installed the Walbro, and changed out the 19# for 24# injectors all at the same time. I had intake, exhaust, pulleys, fans, and ignition all done already. It's pretty quick for an old 4.6 truck and plenty light with manual trans, 2wd, and reg cab.
enb
Old Dec 31, 2006 | 11:43 PM
built54's Avatar
well if you got yours tuned in fine, im sure i could too, and id hope to gain a little, im sucking a lot more air than stock!
