F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Chips, Tuners & Programming (https://www.f150online.com/forums/chips-tuners-programming-34/)
-   -   I've Been Edged (https://www.f150online.com/forums/chips-tuners-programming/265420-ive-been-edged.html)
NHSP-06 Dec 20, 2006 11:59 PM
I've Been Edged
So I pursuaded the old lady to give me the christmas present early this year and installed my edge tonight. Turned that sucker right to Level 3 and adjusted for tire size and gear ratio and took off. I must say, I am absolutely pleased with the way this thing works. Not only can you feel such a difference but just all the displays that you now have right at your fingertips is just awesome. I'm going to play around with some of the custom settings tomorrow and see if i can get maximum out of this thing, but not 100% sure as to what exact settings I'm going to use. I've been looking at others' settings and was wondering if you guys could give me some updates as to what you are now running. Totally pumped about this unit:rocker:
Thanks in advance for your guys' input.
MrToyMan Dec 21, 2006 12:56 AM
Been Edged Here Too. Adjusted the tires only so far and using level 2 until i can fill her up with 91 or better.
I installed the Edge after my 6" Rize lift install with 35" Toyo MT Tires and wife first comment was " Whoa, She's FAST ". :eek:
BABA4488 Dec 21, 2006 01:26 AM
Merry xmas guys, I'm considering geting an edge, but i was just wondering if you burn alot more fuel with the edge???????? Even if u do im sure its worth it
Hash278 Dec 21, 2006 02:43 AM
Hey bro just one question have you regeared you truck or are you just running the edge with the 35's
MrToyMan Dec 21, 2006 02:46 AM
No i have not change my gear, still using the stock 3.73. I believe you must only change gear if you go 37" or higher.
Hash278 Dec 21, 2006 03:09 AM
[QUOTE=NHSP-06]Turned that sucker right to Level 3
I have one more question about the edge. What are the different levels that it has as you mentioned your on level 3. Are they different HP increases like the desiel tuners. I was thinking of swiching to edge evolution, is that the one that you have. :banana:
Bluejay Dec 21, 2006 09:47 AM
The Edge actually increased my gas mileage slightly, and that is with driving it more aggressivly. You have to feel the kick or why have it.:lol: Oh wait, I wanted it for the gauges. That lasted only till I drove it on Level 3 the first time.
05supercrew Dec 21, 2006 10:15 AM
Get it you will be very happy. You should get better fuel mileage.
