98 F250 LD Programmer question
I have recently purchased my first of many Ford trucks. I have begun toying with it and have upgraded to a larger tire size. When I upgraded from stock to a 285/75 15, I lost a good chunk of my fuel mileage. I was reading on the Hypertech and found out that I can't change my tire size and gearing with this particular model. I was wondering if anyone knew of a programmer that would allow me to change the tire size and regain some fuel economy. Any suggestions would be appreciated.
All you have to do is buy a new vehicle speed sensor gear. Not sure what one you need, but it shouldn't be more than a few bucks. Also, your tires are at least a 16" rim....
On your truck, you will need to change the VSS gear. But, you can still get a power programmer. Your best bet would be to go with a XCalII tuned by Mike Troyer or an Edge Evolution chip which I have and love.
OK. I have been looking at the XCal 2 and seems to be the best for what I am looking for. Thanks for the help.
One more question! (at the risk of sounding dumb) How is the VSS going to help gain back fuel economy? I guess I am just not sure what the sensor does beside recalibrate my speedometer. :confused:
The larger tires are throwing off your spedometer, which is in turn causing you to miscalculate your gas mileage.
That makes alot of sense. Thanks for all the help.:thumbsup:
Yes, exactly - the speedo being of also throws off the odometer and in automatic transmission models, the shift pints as well - so with the odo off, you can't calculate the fuel mileage accurately.
In the Ford F-series the ability to recalibrate the speedo via flashing the PCM starts with the 1999 model year. :) |
