Plz explain what a TEM7 code is?
Old Oct 18, 2005 | 02:13 PM
raider's Avatar
Originally Posted by Norm
Because you know damn right well that Mike knows the difference between a calibration code and a trouble code. We all know your agenda.
Norm you dont know *****...Did I say anything about Mike not knowing difference of a DTC and a "code"?....I asked the ? because I didnt know what he was talking about and I posted that I misread what was posted....then you and others decided to take the thread to another level....I am the only one on hear that will admit to being wrong about something
Old Oct 18, 2005 | 02:43 PM
Norm's Avatar
Originally Posted by raider
Mr Troyer has stated that some trucks have a "TEM7" code from the factory...can you explain to me why you use this term when if you checked the DTC's chart this code is not present? all pcm codes start with a "p" and bus codes start with a "u"...example of a lean code is p0171 or p0174
Clearly looks more like you are trying to educate Mike about the difference in code types. No real question there.
I have been wrong before and will be again. I have admitted that on this website in the past as well. That does not make me wrong now.
Old Oct 18, 2005 | 02:54 PM
raider's Avatar
jesus man...read it again...."can you explain to me why you use this term when if you checked the DTC's chart this code is not present"
thats was the question...and it has been answerd
and your wrong again
Old Oct 18, 2005 | 03:05 PM
Norm's Avatar
You are so transparent.
That "question" is clearly leading.
But I will let you have it your way.
I am wrong in assuming that raider is incapable of asking Mike a question without an alterior motive. I should not be so quick to judge him even if his history shows otherwise.
Old Oct 19, 2005 | 12:49 AM
JerseyGeorge's Avatar
Norm how was this anti anything? I asked a ? about the code and I missread what he was talking about...
Your not asking a question to seek knowledge....you asked the question because you thought you could make an Azz out of Troyer.....instead you proved who the azz is
In your quest too make Troyer out to be the Anti-Christ you constantly put your foot in your mouth!
Old Oct 19, 2005 | 09:08 AM
raider's Avatar
Jersey and others you guys dont have a clue as usual...if I want to make a a$$ out of anyone I can...that wasnt what I was doing here....I asked a freaken ? and thats it...if you wannabe's want to make this a pissin match count me in
