Xcaliber question
Old Jun 7, 2005 | 10:34 AM
Thumper38's Avatar
Xcaliber question
How many times can you reflash the computer on the vehicle? I have had my Troyer Xcaliber for a week and it is awsome I love the shifting and the throttle response, Thank you Mike for your help you defindently have your sh*( together! I just want to know if there is a limit on how many times I can change the programs?
Old Jun 7, 2005 | 01:06 PM
Former Sponsor
Hi Thumper,
No, there is no set "limit" on how many times you can reflash the PCM - you can do that as many times as is necessary over the life of the vehicle.
Now that being said, I don't like flashing the PCM more than is necessary - so I wouldn't do that a dozen times every month, etc., instead I would treat it like the BIOS in your PC - as long as it does not *require* changing, leave it alone, as a general rule.
But there is no inherent limit to how many times you can flash the PCM - you can go back and forth however many times you need to get the job done with however you use your vehicle and based on the types of tunes you have, etc.
Glad you're enjoying our custom tuning!
