Mike, Superchip reprogram, when?
Mike, I just purchased the Superchip and am impressed. When I oredered it I stated that I had a K&N filter and Ravin Z-33 muffler. Did I recieve a program for a stock F-150 or do you have chips on the shelf for different common mods? Also, at what point should I (we) consider getting a reprogram? I was thinking FIPK or ram air and maybe opening up the exhaust a little more. Of course I allready know about discharging the electrical after mods.
Thanks...G
2000 XLT
5.4L, 3.55ls
Toreador Red
Supercab, Short bed
K&N air filter
Raven Z33 muffler
Hellwig rear sway bar
Superchip
Cervini's ram air hood shipping
Thanks...G
2000 XLT
5.4L, 3.55ls
Toreador Red
Supercab, Short bed
K&N air filter
Raven Z33 muffler
Superchip
HI!... GEEKY666 : You don't have to get a "CUSTOM" SUPERCHIP program for basic mods. The standard SUPERCHIP program is compatable to work with POWER PULLEYS, ELECTRIC FANS, EXHAUST, THROTTLE BODYS, AIRRAID KITS, and HEADERS. Though SUPERCHIPS does have an aditional "CUSTOM" program for headers which yeilds about 5H.P. The only time you need a "CUSTOM" program is when you run a PRO-M, SPEEDO CORRECTION, PORTED HEADS, N.O.S, EXTRUDE HONED INTAKE, SHIFT POINT CHANGES, REV LIMITER CHANGES. You should be fine with the mods you have done and plan to do.
Mike T. if I have forgotten anything, just correct me!LOL!
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Hi Geeky,
Neal pretty much hit it on the head, you don't need any reprogramming for things like K&N air filters, exhaust changes, airbox kits, etc. You only need custom programming when you do major mechanical modifications to the vehicle, as a general rule. One exception is aftermarket mass airflow meters (MAF's), we're finding that more and more often they lean out the A/F ratio these days and that must be compensated for, but that aside, it's generally the major mechanical modifications, not the simple bolt-on stuff.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Mike Troyer
(540) 862-9515
