computer chip and a rv
Hi sk1,
Yes, there are many here that do exactlyh that - the way to access that info is with the search engine here - it's easy to use, the icon is in the upper right portion of your screen here. Just search on "towing," and only in just the Computer Chips section, and you'll instantly pull up tons of posts from people who have posted their results - some great ones are by "Family Ride" and from "Conocoan" - they talk about everything from towing performance to fuel mileage results to you name it, before & after installing the Superchips tuning.
If there is anything you would like to know about in detail, you can also feel free to give us a call if you like, our number is listed just below & we'll be happy to answer all your questions, go over exactly what you can expect from the Superchips tuning, etc., so you can give it some thought, if you like.
Happy Reading & good luck!
Samkirk1
I pull with mine all the time. In fact, I would say that since I drive a little hoopty to work on most days, the truck is primarily driven on the weekends and usually involves towing. I have the Max tuner installed at the 87 octane setting and I like it. Don't expect it to act like a new truck or anything but it definitely helped some. Any little improvement I can get...
Agreed, do a search and you will find a lot of info.. I personally have towed a RV camper with mine - 19 footer (hardside) to be exact and it towed like a champ. I regularly tow a boat at ~3k pounds w/out problems and anything else that needs to be pulled. Pulled a 21 ski boat a few weeks ago and it was a piece of cake!
