Question for mike?
Old Sep 21, 2003 | 09:21 AM
chrisely24's Avatar
Question Question for mike?
I am buying 4:10 gears this week to replace the stock 3:55's
Do I need to have my superchip re-burned?
Old Sep 21, 2003 | 11:06 AM
GearHead_1's Avatar
I'm not Mike but your answer is YES.
Old Sep 21, 2003 | 12:49 PM
Fritzthecat's Avatar
I am 'a' Mike and my answer is no.
In the 1997 model you need to change out the VSS gear on the tranny. About U$20 at the dealer. Takes about 10 minutes to install. Search the forums to see which color/teeth count you'll need.
If you have a truck with the digital odometer then yes, the chip needs to be reburned or use a 1715 tuner.
Fritz
Old Sep 21, 2003 | 04:14 PM
GearHead_1's Avatar
Mike's right, I missed the 1997. Sorry.
Old Sep 22, 2003 | 08:12 PM
Former Sponsor
Hi Chrisely24,
Nope! You've got it easy, up thru and including the 1998 model year, you just change the traditional speedometer gear, located in the tailshaft of the transmission in the automatics.
It is only in the 1999 & newer trucks that we *have* to do that in the PCM program, either in a custom Superchip or via the Micro Tuner.
So you've got it easy, a simple $10-$15 speedo gear & about 10 ,minutes is all it takes - that will also fix the shift points in automatic models as well.
Have fun!
