Nasty, nasty water!
Nasty, nasty water!
My city has to have the absolute worst water I've ever seen!
On top of it all, the humidity is so low, that the front of my truck will dry while I'm washing the rear! It leaves a nasty, dryish coating on the truck.
My usual method is to try to keep it wet all the while I washing it. I then remove the nozzle and use a slow stream to eliminate most of the droplets. I then use a Megs water magnet towel, patting the vehicle to dry it. Then, I absolutely have to go over the entire thing with Megs QD to remove the very thin layer of "stuff". The end result is micromarring and swirl marks in the paint.
I am interested in ALL replies to this post. I simply have to find a better way to doing things than I am currently doing.
I've thought about catching the rain water off the roof into a barrel and using a submerged pump to do the final rinse. Anybody ever tried this?
And no, we don't drink the city water, at least without the benefit of Britta!
on
1 Post
http://www.autogeek.net/optimum-no-rinse.html
1. Hose off vehicle
2. wash w/ONR-water-mix, as instructed. Start at roof of vehicle and wash/dry your way down, panel by panel. Use a "microfiber dreadlock" wash mit and dry with a microfiber towel. Don't worry, the paint won't scratch as the ONR protects it. I also utilize the "two-bucket" method.
3. I blow off the panel before drying with a leaf blower, but this step not necessary if you have a supply of dry MF towels.
4. Stand back and ask yourself why you didn't try this earlier.
Thank you for replying.
I think I'll try it on another car before I use it on my black 150.
Right now, I'm leaning toward catching the rain water off the roof into a drum and using a submersible pump for final rinse. Of course, that's a lot of work and monkeying around, but...
on
1 Post
Believe me, your paint will be fine. I'm a perfectionist and would do not hesitate to use ONR on my Lightning.
Just google it and read all the positive reviews.
I don't know if rain water would hurt. If I leave it out in the rain, sitting in my driveway, and let it dry, it has no spots. Problem is, it doesn't rain that much around here so I can't count on it for rinsing without collecting it.
I don't use a tee shirt or towel or diaper. And the ol' lady doesn't wear panties, so that's out!
Actually, I use Megs water magnet MF towels to pat dry. Then I go over it with Megs QD and a plush MF towel. After one season though, I still see light swirl marks. And yes, I do wash in the shade.
I thought about one of those Whole House filters, but was told it would not be enough.
Maybe I'll just go buy 5 gallons of distilled water at the supermarket. It's only about a buck a gallon. I'll use it in a pump sprayer for final rinse.
Or paint the damn thing yellow and then I won't see swirl marks!
I'd be leery of grit in the rain water, especially off the roof if you have asphalt shingles. I've always got a layer of it in the gutters.
Our water is horrible as well. We get nice white deposits in our hoses and fittings. I setup a double canister filter from Autogeek and it helped pretty well. it's not perfect, but a lot better.
I have to wash the car/truck before 11 am, after that I get nothing but sun. I usually wash the wheels and tires first. Then wash the cab, dry it. Wash the bed and dry it. Seems to cut down on the break neck pace of trying to wash and not letting anything dry.
Combined with some other suggestions mentioned here (washing in the shade, and when it's not so hot) I get good results.
I also don't use a nozzle anymore, but just let the rinse water "sheet" off the vehicle by using a low pressure stream from the garden hose.
(Meaning, no aeration of the water causing more water spots)
OK, now that might be a bit much!
