Can this or will this end the clay bar? - NanoSkin AutoScrub
NANOSKIN Autoscrub 6 inch Pad - Better and Faster than Claying
Wow is all I can say about this new tool and new technology. I believe this will change the way most pro detailers and DIYers will prep their cars. This is truly a time saver and will pay for itself after a couple detail jobs. We have spent in some cases 1-2 hours claying and prepping a midsize sedan (in rough shape) we recently tested the AutoScrub on an Audi S8 and we were finished in about 15 minutes! You really won't believe this until you try it yourself. The AutoScrub will make you leave your clay bar behind.
NANOSKIN AutoScrub works fast and achieves professional results with the new advanced rubber polymer technology, which replaces the use of clay bars.
A dual action orbital polisher is required. AutoScrub will safely and easily removes paint over spray, water spots, tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic.
AutoScrub works great with your favorite detail spray or clay lubricant. Unlike the clay bar, the AutoScrub can be cleaned by simply rinsing off the accumulated contaminates with water. If you drop the AutoScrub on the ground, no worries, just rinse the sponge pad clean and you're ready to keep using it.
AutoScrub allows for sturdy and controlled handling, unlike clay bars where constant reshaping is required.
Features
- Lasts up to 4 times longer than clay bars
- Glides on & off easily for a slick finish
- If inadvertently dropped on shop floor, simply rinse clean
- Up to 50-60 uses before you need to replace it
Directions
1. Thoroughly wash vehicle free of dust, sand, and dirt.
2. Mist sufficient detail spray or clay lubricant onto the surface evenly.
3. Polish the surface with dual action orbital polisher using light pressure (Low Speed).
4. Wipe off residue and move on to compound and polishing or even go straight to your last step.
Important tips:
- Sufficient lubrication is crucial to the AUTOSCRUB application.
- DO NOT use water
- DO NOT use with rotary polisher.
Take a look at the 3 offers we have. Pre Order Pricing is in effect, we should have the first wave by Friday.
NanoSkin AutoScrub 3 inch Kit
NanoSkin AutoScrub 6 inch Kit
Nano Skin AutoScrub 6 Inch Pad
Various photos of how the pad looks and works
3 inch pad kit
6 inch pad on the Griots on an Uber 5 inch backing plate
Features
Directions
Important tips:
- DO NOT use water
3 inch pad kit
I have only had 1 vehicle in 30 years that required "clay-bar" to remove the contaminents......this is clearly just another "Toy" that is designed to make money for an item that has "Bling' but serves no real purpose that isn't already accomplished by existing resources that with greater effectiveness and less cost to both the user and client...IMHO, of course!
on
Don't come into a Site sponsor's thread and bash their products.
They are paying to keep the site free, even for a troll like you to use.
You have as much class as Takeda in this regard....
If Megs doesn't make this product I am not interested and I cannot blog it.
Kidding of course, I am actually very interested in this one verses some of the other clay alternatives out there. I like to see a few different test videos for this...one on a pretty well maintained surface and one on a very neglected surface....one you could feel crap in the paint.
BTW, how often do you need to rinse the pad on a job? So for each section with clay, you fold and go right? Same process? Maybe give it a rinse on each side of the car/Truck?
I've got enough clay to go another year or so, but if the mother in law brings her car over and wants it done in an afternoon this may be the ticket.
