Swirls and products
Old Dec 23, 2007 | 03:33 PM
Richhit's Avatar
Swirls and products
Ok so I have swirl marks in direct sunlight. My question is what products should I buy(towels/wax/polish) and what order should I apply them. Anything will help guys. Thanks
Old Dec 23, 2007 | 06:06 PM
RUSS04's Avatar
Read the stickey in this forum It will help you out Alot of good info :santa:
Old Dec 23, 2007 | 08:05 PM
Rockpick's Avatar
Moderator &
For a lot of us here, this is kind of an open-ended question that could be replied to for a plethora of posts...
The sticky atop of this forum will help you along the way and will likely clear up a lot of the common questions that go along with a job of this caliber. While you will be able to remove simple swirling, there are several ways of going about it and there are several products. Give a little bit of time to searching within this forum and also reading the PDF. I think you'll come away with some clarity and, from there, we can fine tune your plan with a few additional posts.
I hate to just play the 'go read the sticky' card but, in this case, I think it's a pretty good starting point.
Best of luck and please let us know once you've done some research and have additional questions!
-RP-
