backing plate and pad size
I have been using a 5" backing plate with 6.5" pads. Is this pretty much the standard setup or should I be using something else. Thanks :)
http://www.meguiarsonline.com/galler...PadSpeedPC.JPG
Additional considerations The above recommendations are only a starting point. Keep in mind; there are many variables, which contribute to the overall performance of a product, and the end result. For example: 1) Paint Type of paint, age of paint, hardness of paint€¦all of these play into which pad and product will work best for that particular application. 2) Pressure Increased pressure means increased cutting action In some cases this is needed, and in other case this could be detrimental to the surface. 3) OPMs By increasing the OPM's of the machine, you automatically increase the action of the machine. This means additional cutting action for when using products that have swirl removal capability. However, if you're simply spreading, you should reduce the speed of the machine at this stage of application. 4) Arm Speed The quicker you move your arms back and forth, the less chance the product has to do it job. For example, a swirl remover needs to be allowed to work itself into the surface. The slower the arm speed the greater chance of removing swirls. 5) Pad Choice The more aggressive the pad, the more cutting action will take place. You must first evaluate your finish, determine your goal, and then choose the appropriate pad to do the job. 6) Product Choice - You must first evaluate your finish, determine your goal, and then choose the appropriate product to do the job. |
