Any suggestions on putting a rack on my shell
I'm lookin at putting a rack on top of my camper shell.
Can anyone give me some advice on what product to use. And what all I have to buy. |
The top shell will need holes drilled, which means you'll need to make them weatherproof. So measure and align your holes carefully and accurately. Then you can use either rubber O-rings around each bolt, or caulking or a tube of liquid gasket maker. Blob it on in excess, and just wipe away the squeeze-out. I'd treat it like you were doing a faucet or a sink's drain, using plumber's putty.
Does your shell have a reinforced top? The shell (don't know what brand, but a cheap one) I just sold did not but someone had installed ribs to support something on the top. The bolts for those ribs are painful to the head when I bumped them even though they were covered with RTV or something.
The shell I recently bought off craigslist is an ARE model and it appears to have a sheet of plywood molded into the top. It's a much better made shell. |
I know some guys here have the ARE cap with yakima rack on top.
If you can find a store that sells Sex Bolts (sometimes called barrel bolts) then you can have both sides with flush surfaces and still have good holding power.
Do a quick Googling for sex bolts or barrel bolts, and you'll see what I'm talking about. |
I bought and installed rhino rack rails on the top of my Raider topper.
Rhino rack. I have kayak mounts on the crossbars and transport our kayaks up there when towing our trailer. I had to drill 5 or 6 holes through the topper for each rail. They came with plastic covered nuts that sit on the underside, inside the topper. They are 3/4 deep and don't cause any issue inside. You could even add some other mounts (for fishing rods, etc) to the same nuts inside. I don't keep the crossbars in place unless I need them. They remove in a couple of minutes. Amazon sells all the rhino stuff at pretty good prices. Easy to install. |
hi thanks I am also curious about this. Can someone dumb this down for me? When I got to home depot or lowes, which screws/bolt do I need to get, which caulk, and glue? Noted that there are a million options and variations of things... and I am a newbie to this.
This is for mounting solar hardware on the top of the topper, which is fiberglass I think, with carpet liner on the inside thank you! |
