Undercover Swingcase Reviewed
I'm bummed because the Swingcase I bought doesn't fit my '01 Flareside. I bought it off Amazon.com. There wasn't enough info on the site. I learned after I test fitted the swing case today that Undercover states it will not work in the Flareside. Too bad! This thing is really nice. A great idea if you need storage like I do. I have an Aere fiberglass top that is painted to match. The bed has a duraliner w/ Ford logo. I moved the bed liner to test fit before cutting the bed liner to install. Good thing I did or I would really be bummed! I recommend the swing case to anyone that needs storage. Mine is going back to Amazon.com. I could use some advice on other types of storage. I want to store a jack, recovery strap, winch accessories and misc. stuff without it all sliding around the bed. No room in my Supercab. I do not want to let stuff roll around in the bed or take up too much space. The swing case would have been perfect if it fit. I was going to buy one for each side. Now I am back to square one.
I have been thinking about purchasing one of these for some time now. I finally pulled the trigger and got it from Amazon for $184, plus free shipping. It seems very well constructed. The mechanism that locks it into place is heavy duty and it makes the same sound you hear when opening and closing a car truck. The waterproof seal on the cover is thick, and you have to push down on the cover to lock it. I had to remove a tie-down to install it. Now I can keep all my emergency stuff out of the cab! Here are some pics.
[IMG][/IMG]
[IMG][/IMG]
I sure wish the swing case had fit in my flare side! I really liked it. As you can see from the previous post it is easy to install and well constructed. It also tucks out of the way and latches securely in place. I would recommend it for sure. Now I need the company to make one for the flare sides! Thanks for the post and photos. SMM
PirateSignal,
You should be able to still use the rear tie down. Just flip it over so it sticks out under the bar. Works fine for the '09+ at least, and the loop looks the same as yours. You'll have to swing out the box to access the loop, but its no big deal. I use it for tieing down light stuff all the time.
If you need to tie down something that's tall or heavy, the box will be in the way of your strap and might get damaged from being pulled on. In that case, remove the box and put inside the truck or leave it home for that trip.
PirateSignal,
PirateSignal,
How are you liking the swing case so far? I was wondering if you could answer a question for me. In picture #3 where the plate mounts by the tailgate, what is the depth of the bracket to where it turns forward at the bedside? Hopefully my diagram helps explain better what I am looking for...
Thanks,
John
Thanks,
John
I never got an answer from anyone here for my question...
Frome the company I got:
We have never made a Swingcase bracket for that truck. We have a semi universal kit that some customers have made work for that truck. We don’t have any measurements or what they did to customize the bracket but they did get them to install in that super crew bed.
Model # SC900D & SC900P
I have attached to this email the installation guide for that model Swingcase. It shows the brackets that come with that model.
If you have any further questions please let me know.
Thanks,
Chris Lundberg
Customer Service Manager
866-900-8800 Ext 406
I had found a pair on CL that was cheapenough that I was going to take the risk but never got answer from the poster...so I still don't know if they wii work
Thanks,
Chris Lundberg
Thanks,
Chris Lundberg
Thanks,
Chris Lundberg
Thank you for the pics PirateSignal. I refer customers to this item often. This thread will be very helpful.
Heath Copp
President, Peragon Enterprises, Inc.
www.peragon.com
Heath Copp
www.peragon.com
They are closed now, but you can try calling tomorrow. Their number is 866-900-8800.
Maybe someone else here knows.
Heath Copp
www.peragon.com
Heath Copp
www.peragon.com
