Bedliners, Caps, Tops & Lids
Line-X, Rhino? Differences?
Old Aug 9, 2005 | 06:10 PM
TruckGasm's Avatar
Rhino: You said, "most of them facts are out of line", seriously which facts are you referring to?
You said Rhino is about the same as LINE-X. How do you figure?
I'm here to answer questions about bedliners because it's a passion. The chances of me actually getting business from being here is slim to none. It's not like I have a product I can ship.
Old Aug 9, 2005 | 07:32 PM
rhinolinings's Avatar
Originally Posted by dmelchi2000
This is actually Smelchi not Dmelchi. I am using his log in because I forgot my password.
RhinoLinings answer this question for me. I am not trying to start anything just want the facts.
If Rhino linings dries so you can walk on it and use it like it had been in there for a year in 9 secondes. Why do all the Rhino stores in my area want the truck for at least 24 hours before they let the customer take possesion of the truck? They also won't let the customer put the tailgate up for two days and no use of the truck for three days. So does it really dry in 9 seconds to the same hardness as Line-X?
Because I can get a bedliner done in an hour and a half and the customer can use it right away. So what is your definition of dry? Or should we really be using the term cure time until full use?
Just wanting to know because I use the fact that Rhino takes so long to set up as a major selling point. And trust me I have rarely and I might even go so far as to say I a have never seen a Rhino lining that didn't have drips and runs in it from the application process. Maybe the three guys in my area aren't good at what they do but it sure seems like a flaw in the material or process for that many of them to look that way.
okay well yea you cant walk on it right away about 15 minutes later i would say but then the texture can get pushed down a bit .
yes 24 hours is a full cure time for rhino after it is sparyed it is 98 percent cured 24 hours for full cure time .
as for them leraving the tailgates down that is stupid cause rhino wants you to put them up so if it is touching the tailgate it will smush down so it can close properly . as for they want the truck for 24 hours they must not be doig there job right i myself no help needed can do 3 to 4 trucks a day by myself . and the customers pick them up right away with the tailgate closed and the rhino not wet . or anything . i would liketo see there work cause if they have drips they need to learn how to spray i will get some pics up on here for you guys to see my work . and what my rhino looks like . and i have done just about 1000 trucks to date since i started about 2 1/2 years ago now buisness is up and running great i am looking to do about 500 trucks a year . plus all my other work we do rustpriffing accesorys etc . but let me get some pics up for you to see the custom work i can do .
we spary chairs for a company they are foam chairs that go into schools and bars , and all kinds of places try and do that with linex . all kinds of colors . we do these special boat bumpers for cruise ships with rhino at my shop . i mean these things are like 3x4 and 4x8 foot in size . my shop is being recoreded by mtv this august for us spraying the chairs so i will let you guys know when it will be aired so you can check it out . we do alot of wierd stuff plus all the trucks but like i said to each his own both great products and what you have heard about them is incorrect and false and the guys must really suck by you for there time to keep trucks and tell people that
Old Aug 9, 2005 | 07:35 PM
I think this discussion may be getting a bit too heated and for that I apologize, Smelchi it honestly does seem that the sprayers in your area are incorrectly applying the rhino or perhaps dont have there spray environments as ideal as they should be. We release our vehicle's directly to our customers once they leave the spray both if they so choose, tailgate up and ready to rock and roll. The only type of wait we recommend is that they dont abuse the rhino excessively for the 1st 24 hours so that the texture, meaning the actual top finish of the rhino has a even look completely across. In all honesty they more than likely could use it before that, however we just use this as a precaution. I have yet to see a truck, utility body, van etc. leave my location with any type of an imperfection, however like I said this is speaking from personal experience and perhaps its our preparation or application that makes for such great results, maybe the line-x application may be a bit more fool-proof i guess you could say, however to that I cannot attest.
Old Aug 9, 2005 | 07:52 PM
how cause they are both bedliner products they both do the same thing for a truck protect it and make it look a little better . you say you have a passion you think i dont . so your truck can be used right away where mine i ask that you use it 24 hours later yes your pray does look more clean looking but that is because it is a high pressure let me ask you this about how much chemical do you use on a truck . say ford superduty 6 foot bed . but i have seen every liner out there and linex aint close to the thickness of a rhino lining . and it is way to hard for me things slide on it . it hurts your knees . so in my eyes i would rather have a rhino lining anytime . getting buisness sure you will people in your area will come to you . and just putting the name out there helps all dealers this site was flodded with linex well time to get rhino involved to i posted cause i didnt likewhat i was hearing . that you were saying about rhino linings cause your theorys where wrong . and can make people think that they have options . the things you where saying where so far fetched i actaully laughed like the stuff sliding to the bottom of the tailgate . what a dumb thing to say anyone with common sense would say well wouldnt the walls do it to . a little common sense goesa long way no lner could be like that where it takes days to cure cause with that said if the tailgate was down dont you think doing 70 on the highway would make the hole bed slide to the rear from wind . not trying to start just want to show people that they have options and try to show you that your theorys are wrong . enough said people go check them both out . both good products if done the right way
Old Aug 9, 2005 | 10:26 PM
creed123's Avatar
Thumbs up
I'm new to all of this, I do know that some of the Rhino info is correct. The body shop in my town won't let it's customers pick up their truck if it is raining, and they always put them outside to cure with the tailgate down, I don't know why but every one of thier trucks has the tailgate down. One of their sprayers said it is because if they close it the lining will cure to its self and cause damage when the tailgate is opened after it is fully cured. I also know that when I bought my new GMC at Ed Schmidt I was given the choice and showed the difference and the Line-X looked FAR more clean, uniform, and factory than the Rhino. The Rhino's finish was NOT uniform, there WAS little drips on the rails as well as on my tie downs, was not impressed. The dealer also told me that Rhino fades very fast and is prone to puncture damage because it's soft, the Line-X warranty also was better, apperantley the lifetime warranty was only at THAT shop, not at any other rhino. Just giving my experience Rhino may be a good liner, but from everyone I've talked to (including the dealership) Line-X is the only way to go!
Old Aug 9, 2005 | 11:28 PM
drvn2win's Avatar
Glad to know ....
Originally Posted by Norm
My Line-X'd truck gets used like a truck. Lightning Bolt's first post here is to insult, bodes well for his future doesn't it.
dudes on this site have some substance. Rookie here, Joined to listen and learn from others experiences and share my own. That stopped at high school for me.
thx norm
Old Aug 9, 2005 | 11:55 PM
suncoast ford's Avatar
Linex does look much better, rhino looks like someone sneezed all over the bed
Old Aug 10, 2005 | 07:33 AM
creed123's Avatar
Talking
Lol
Old Aug 10, 2005 | 07:53 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
I got the best of both worlds.
The Rhino was priced better, so I went that route and then put a Line-X sticker on the truck to impress all the guys at the dump.
There were a lot of 'ooohs' and 'aaahs' and compliments when I pulled up and was unloading my refuse.
When I was leaving, one of the county workers, I think it was the guy with the rake, looked in the bed and said,
"Hey man, did you sneeze?".
But I just acted like I didn't hear him and got the hell out of there fast.
Old Aug 10, 2005 | 09:32 AM
TruckGasm's Avatar
Thats FUNNY!
I spent a lot of time researching the bedliner industry. Those who use a bedliner product certainly offer very valuable first hand experiences. My posts deal more with the products' chemical and physical differences because most people don't know or have access to that additional information. All tires are made of rubber, but tires can have VERY different physical properties. The same goes with bedliners.
So, here's some more info for you. Like tires are made of rubber, bedliners can be of 3 different basic components:
1. 100% polyurethane
2. 100% polyurea
3. Mix of polyurethane and polyurea
Both polyurethane and polyurea give the bedliner desirable properties. For example, polyurethane has 2 to 3 times the abrasion resistance of polyurea. Polyurea, gives the liner a higher temperature tolerance and tear strength. The best liners contain a mix of both polyurethane and polyurea. Polyurethane is inexpensive, polyurea is more expensive.
To take it a step further, there are two types of polyurethanes: One-part polyurethanes (also called "solvent based") and two-part polyurethanes. One-parts work like this: The polyurethane is suspended in a solvent. A catalyst is added that polymerizes the solvent and leaves just the polyurethane. The catalyst can be a liquid chemical or just air. Two-part polyurethanes work like this: A polyol resin is mixed with isocyanate (a hardener) which renders the polyurethane. Two-part polys are typically harder and much more durable than one-part polys.
Brand Examples:
Mix of polyurea and polyurethane (two-part): LINE-X, Vortex, Ameraguard.
100% polyurethane (two-part): Rhino, Toff.
100% polyurethane (one-part): Superliner, Speedliner, Herculiner, Durabak, Duplicolor.
100% polyurea: Xtreme Liner, Combat.
All the big bedliner companies have done some pretty incredible things. LINE-X has a product called Paxcon (www.paxcon.com) that has been sprayed inside the Pentagon, Federal building in New York and LINE-X has the current contract to spray inside US nuclear submarines. The military uses bullet proof vests. The plates inside the vests are made of titanium and ceramic. There are about 50,000 plates in use in Iraq and Afghanistan and they are all coated with LINE-X. LINE-X dealers have access to about 5 different spray products. There are about 20 more products available (like elastomer foams), but special equipment is need for those.
Here's a military satellite communication trailer that was sprayed at my shop and then shipped to Iraq, we sure were proud that day!
Here's one of those plates being presented to D. Runsfeld for saving this soldiers life (he was shot in the back by a sniper):
Old Aug 10, 2005 | 10:43 AM
im guessing half of the rhino dealers that you guys are around are not worried about looks of there product . cause i would say on of the things i like about hino is i can make whatever texture i want with it . depending on how much air and flow i use . let me get some pics up to let you guys see what i mean i ask most of the customers do they want a fine texture or a rough texture up to them . where the high pressure systems only have that fine texture do to thats how the product comes out . where rhino is sprayed and then textured
Old Aug 10, 2005 | 11:25 AM
Newt's Avatar
The September issue of American Rifleman just arrived. It has a very good write up on Line-X. My new Lariat was sprayed last Tuesday
Old Aug 10, 2005 | 11:32 AM
TruckGasm's Avatar
Rhino: You are incorrect, sir. LINE-X dealers can also vary the texture. I've sprayed (for example) lawn furniture with NO texture at all to VERY rough texture, like large grit sandpaper, on fire trucks. We sprayed very heavy texture where the firemen walk on the truck.
I've sprayed fire brush trucks for several fire depts. Here's one:
Before pic, partially prepped:
After pics; We actually sprayed inside the water tank on this one also. The employee is actually standing in the water tank in the above pic:
Old Aug 10, 2005 | 11:57 AM
dmelchi2000's Avatar
Sorry the pictures of Rhino examples didn't post. I will work on it and post them later. You will be horrified.
Old Aug 10, 2005 | 12:23 PM
TruckGasm's Avatar
Here's a Rhino we stripped out of a truck, we snapped some pics first (it's partially wet):
Notice the bed bolts. Looks like they use a hole saw and cut the liner around the bolts. We remove the bolts, spray, re-install the bolts. I don't have a close up pic, maybe you can see the difference here:
