Bedliners, Caps, Tops & Lids
Bedrug ??s
Old Feb 13, 2004 | 11:14 AM
THNDRSTRK's Avatar
Question Bedrug ??s
I just purchased a bedrug and access cover. Right now I have a Ford bedliner that came with the vehicle when I purchased it. Should I take the bedliner out to mount the bedrug?
My only thought is that once I mount the velcro to the bed itself I will never be able to take it back out (not that I would want to).
Thanks,
Jason
Old Feb 13, 2004 | 08:59 PM
max mitchell's Avatar
If you're talking about a Ford "plastic" drop in bedliner, then you remove it first, before installing the Bedrug. The Bedrug has pads on the bottom that fit and fill in against the bare steel bed contour rails. The bedrug can be removed from the velcro, but many mount the tie downs over it to help secure it.
