How-To: Paint To Match (PTM) Mirror Caps on 04-08 F150
new member here,I have a 07 lariat screw 4x4 I ordered the ptm caps and had them painted only to find out my are a one piece cap. I was wondering if any one here has or knows where i can get the lower mirror cap that i can mount my new upper cap too. thanks for any help or info you have.
X2 I went outside and tried to pop it loose and didnt get to far. Im afradi ill break the glass. Is it the little white clips?
BLK and towpig,
When I did my mirror caps on my '08, you just move the glass around to the lower left corner on your pass mirror (right on driver) and there are three clips holding the mirror on via a ball and socket style configuration. My friend and I gently wiggled the glass, and the ball on the back of the mirror popped out of the socket...no broken glass, no broken clips.
I just looked at my iPhone pics, and I didn't take pics of the mirrorless assembly, but I seem to remember the clips being silver...
Still not clear
Y'all make this sound so simple...maybe I'm too scared to use any force in fear of breaking the mirror. It's not very clear as to to where to put screwdriver and pry..? I need some help here guys. BTW i have the tow mirrors and I'm putting on the chrome skull caps
I started painting mine today. Here is the backside of my mirror. There are a total of 8 little clips holding it on. (2 on each corner)
Here they are from the side. Basically you just need to tilt the mirror so you can just pull these tabs back with your fingers or whatever else you want to use.
