How to Mount a Gryphon (or Edge) in Ashtray
Old Dec 2, 2009 | 01:03 AM
bconnaway's Avatar
So instead of using the provided dash mount for my Gryphon, I decided to custom rig it so it was in my flip-out ashtray. This way I can always leave it in my truck and whenever I park, you just fold the ashtray closed and can't even tell its there. So, heres my instructional:
First off remove the front wood panel (this is connected with 6 clips and can be removed using a flathead screwdriver carefully prying around the edges) and unhook all connections. Then, remove the ashtray by unscrewing the 2 bolts on each top corner. Take this out and using needle nose plyers, remove the clip on the bottom so you can take out actual ashtray set-up. Then, unscrew the 2 screws on the bottom of the ashtray. (Sorry, no pictures for that whole section...).
Now, take the end of the cord that connects to the Gryphon, and route it through the hole seen in the picture which is taken from looking into the hole where the wood panel was.
This is done by running it from the driver side by the pedals into this area.
Next, using a pocket knife or better yet a dremmel tool, make the hole on the bottom of the ashtray housing slightly larger so you can run the cord through it.
Then, somehow create a hole in the bottom of your ashtray. I used a pocketknife, but using something like a drill or dremmel tool would be MUCH faster.
Run the cable through this hole, rescrew the bottom section back onto the ashtray, and run the cable around the bottom and through the small hole that is between them.
Connect the Gryphon, pull the slack cable out, and put the whole ashtray assembly back together. Allow the spare cord to be in the area behind the panel. Put the ashtray back into its slot in the dash and bolt it in, and snap the wood panel back on. And your done...
Works great. Only complaint I have is the shifter is slightly in the way, but you can still see it just fine.
Hope this helps with ideas. Good luck.
Old Dec 2, 2009 | 01:00 PM
screw_firstdate's Avatar
Pretty slick. I bet that would help with night driving. Sometimes, I hate having that bright light in my face late at night.
Old Dec 2, 2009 | 02:43 PM
Titan357's Avatar
nice find, too bad I don't have a tray like that.
Old Dec 2, 2009 | 03:21 PM
J-150's Avatar
that turned out well!
Old Dec 2, 2009 | 03:56 PM
whitt91's Avatar
do you have problems with the gryphon rattling around in the tray? Very nice anyway, ill probably be doing this
Old Dec 2, 2009 | 05:38 PM
bconnaway's Avatar
nope. it fits in there pretty snug. I didnt really use anything other than the size of it forced in the ashtray and the cable pulling it down to hold it in there. so i havent had any problems with it rattling...
Old Dec 2, 2009 | 08:02 PM
craneman's Avatar
Cool idea i'm going to do this with my XM Inno
Old Dec 2, 2009 | 08:32 PM
MudTerrain's Avatar
Pretty cool...
Old Dec 2, 2009 | 10:13 PM
Reece's Avatar
Wow thats a good idea
Old Dec 2, 2009 | 10:17 PM
MTP-FX4's Avatar
pretty good idea man thats cool
Old Dec 3, 2009 | 12:29 PM
IDNC76's Avatar
you can adjust the brightness/contrast
Old Dec 3, 2009 | 02:23 PM
Wade06XLT's Avatar
Excellent idea. Now all I need is to buy the tuner to do the install. Haaaaa
Old Dec 3, 2009 | 09:30 PM
bconnaway's Avatar
Ya, if you click the up and down arrows, it will change the brightness by 10% each time. you can even turn the backlight all the way off.
But i took a picture of it at night with the ashtray closed to show the light leakage.
sorry its kinda blurry, night pictures with a camera phone is kinda tough...
Old Dec 5, 2009 | 01:10 PM
powerz69's Avatar
NICE! When I get mine I'll be mounting it this way. THANKS! Is it easy to remove if needed to?
Old Dec 5, 2009 | 04:05 PM
bconnaway's Avatar
um, not really as i have figured out now... haha. im thinking if you give a little more slack within the ashtray assessory though, that would make it a little easier.
