Niteshaded LED Taillights (High Gloss Shine 56K NO)
Old Jul 29, 2009 | 09:24 PM
  #31
05BlackFX4's Avatar
for fog lights I would do light coats...you are going to drastically cut the distant of light output using niteshades on headlights or fog lights
and it can be used on any plastic housing lights
Old Jul 29, 2009 | 09:27 PM
  #32
mblouir's Avatar
Originally Posted by mblouir
...because I'm looking at buying some aftermarket LEDs to replace my stock tinted lights. OP, what brand are your LEDs?
Where did you get your LEDs and what brand are they?
Old Aug 1, 2009 | 09:21 PM
  #33
05BlackFX4's Avatar
The taillights are lights off Ebay..
Just look for 04-08 F150 LED tail lights....they were 139 I believe and no issues with mounting or leaking. I did re-seal them once I got them though
Several different companies sell them on ebay
here is the link for them:
http://cgi.ebay.com/ebaymotors/2004-...=p4506.c0.m245
Looks like they are $119
Old Aug 2, 2009 | 10:17 AM
  #34
mblouir's Avatar
Thanks for the reply. I'm really wanting to get these and put some Niteshades on them. I did my stockers but they didn't turn out like I wanted them to.
Would you mind posting some more pictures of your truck from rear angles? I'm kind of on the fence with these and would like to see some more shots of them.
Old Aug 3, 2009 | 12:13 PM
  #35
miamiheat55's Avatar
How many coats would you recommed with stock tail lights?
Old Aug 4, 2009 | 04:04 PM
  #36
Im in the process of doing it right now. Am i supposed to sand after the 4th coat of nightshades or just clear coat it?
Old Aug 4, 2009 | 04:25 PM
  #37
rednoved's Avatar
Those lights turned out nice. I have thought about tinting my hellas.
Old Aug 4, 2009 | 07:14 PM
  #38
Im in the process of doing my lights now and theyre looking ok so far. Two things: 1)When i used the electrical tape the goo kept sticking to the light...It was a pain to get off with windex so I ended using goo gone. It took it right off. The only thing is you have to put a little bit on a paper towel because it will take the paint right off. 2) This is for those who have no taken their lights apart and sealed them...When you are sanding with the soap and water only do a portion at a time and dry it, otherwise the soapy water will leaking in on the edges.
Thats it for now. Ill post some pictures tomorrow or the next day when im done.
Old Aug 5, 2009 | 01:59 PM
  #39
330CID 05F150's Avatar
Originally Posted by BLACKOUT FX4
I'm impressed! i though mine came out good... yours came out much better!! i will be re-doing mine now with your method..
good write up
like the truck...looks good with the wheels and tires.....question...do you have any lift or suspension work done to your truck? im looking to put a set of 20x10 wheels on the truck with 325/50/20 nitto tires without changing the stock suspension. I think I may have some rubbing problems with that big of a wheel and tire combo. Any info would help
Old Nov 29, 2009 | 11:25 PM
  #40
musicccguy's Avatar
very nice write up, came out looking awesome!
Old Dec 2, 2009 | 06:31 PM
  #41
MotoVegas's Avatar
In the process of doing this now First coat is drying as I type. Pictures will definitely be up when it's finished!
Old Dec 18, 2009 | 03:38 PM
  #42
CcHARLEYcC's Avatar
I gotta say I keep reading this forum over and over.....going on attempt #3 for my factory tails. I can't get them to gloss like this at all, makes me just want to take them to a body shop and paint factory black/clear over them......kudos again man you really pulled off a clean night shade tone.
Old Jan 6, 2010 | 03:36 AM
  #43
mhockey9090's Avatar
just did mine. Got a thread in the apperance section right now
Old Jan 15, 2010 | 10:25 PM
  #44
Intimidator317's Avatar
can't wait to try mine!!!
Old May 3, 2010 | 01:55 AM
  #45
Bshipe22's Avatar
can you do your headlights the same way?
