I'm helpin my friend, and i need help......
Ok, I was wondering, to power two subs, should my friend get a 2 channel amp, or a 4 channel amp? Thanks alot!
I've got a mono class D amp powering a Thunderform with 2 subs in it. Hope this helps a little.
Bob:D |
Is it 2 channel or 4 channel
It's a one channel class D amp for subs. Works good and doesn't get hot.
Bob:D |
If you could help me, would 2 channel amp work? I just don't understand the whole concept
I think a 2 channel will work.
But I don't know for sure. I think with a 2 channel you have to bridge the amp which I don't know too much about. From what I've read here you can do it no problem but but a Class D amp is preferred.
Bob:D |
We'll figure it out, if i got questions i know where to come.. I've gotta get an amp and put it all together this weekend or next..
What subs are you planning to use? I like using class d amps for subs as the case is smaller, less heat, and very efficeint. You can use a 2 or 4ch amp. Depends on the subs single or dual voice coil. 4ohm, 8ohm 2ohm we need this info in order to help
Ok, my friend is gettin it from Crutchfield:
Two kicker full range truck boxes including: Two Kicker 10" subs.. 6-150 watts RMS/ 250 peak per channel Here it is.... Well they, it includes two http://www.crutchfield.com/cgi-bin/S...ST1000&o=m&a=0 |
These boxes need a stereo signal. get a 2 channel amp and run in in stereo left an right. You can feed those boxes easily with a 50w/ch up to 200w/ch amp. The US Acoustics amps are a good buy for that application.
Sorry, i didn't understand that
Here is what I'm feeding my MTX Thunderform 2x10 T6000s in my 02 L.
JL Audio 250/1 monoblock 2->1 subwoofer amp It accepts stereo inputs and has dual mono outputs. I love this amp! If you need more loud, try the 500-1. The 6x8s are fed with a 300/4. |
How much does the 500/1 run, cus i need one for myself to run my 10" sub
Tweeter wants $550 for one. You might be able to find it cheaper somewhere else.
Tweeter JL Audio 500/1 |
| All times are GMT -4. The time now is 02:34 AM. |
