need help installing now (remote wire)
what are you using for remote to the amp from factory head unit? and what color are the speaker wires on the passenger side? the hu is one from 04 xlt single disk/cassette
Originally Posted by jjntj2003
(Post 3680010)
Just pop off your head unit and tap into all your wires right there. no need to get behind the speaker. As for colors, Low might no off the top of his head, if not, ill check tomorrow when i get to work
Why would you not just grab a ignition switched 12v source from the fuse box in the passenger kick panel? Not mess with toggle switches and pulling out the radio??
fuse box
Originally Posted by 04screw22s
(Post 3682433)
Look at MTX's website and search for the thunderform enclosure under their products section that is meant for our trucks. Once found, open the .pdf manual and scan through it - it has the wire colors under the door sills for installation of their product, just use it for yours haha. I did this for my '06 F-250 and my '05 F-150 and their instructions are spot on.
Originally Posted by JJDH
(Post 3682448)
first not everyone likes to mess with the fuse panel, second a toggle switch on the remote gives u the ability to turn just the subs off and still have the radio play, second we used to do that so we had a quick kill switch to avoid johnny law, when there is no dedicated sub off switch on the radio, i personally find that to be a hassle. make sense.:smoke:
12v switched wire, on my truck its the thicker red wire that goes to the HU, not sure about yours
Originally Posted by abervintageman4
(Post 3682690)
Ahh just saw the year of your truck..... Have no idea about yours.
switch
(Post 3682685)
Hmmm..... I guess I am old school. I always used fuse taps and found a switched 12v signal in the fuse box. (Most of the time it was the radio fuse). The toggle switch seems a little dangerous and cumbersome in case you accidently leave the toggle switch on....click click goes your ignition the next morning.
Okay then maybe you can learn me.... why would you put a toggle switch on it?
Just to turn the amp and sub off manually? Seems a little weird for me. Seems like plugging in a bass control knob would make better sense. IMO |
(Post 3682781)
Just to turn the amp and sub off manually? Seems a little weird for me. Seems like plugging in a bass control knob would make better sense. IMO on a factory radio that doesnt have a remote, u need to find a 12volt switched source right?. now if u run it off the fuse box, that is great, i did that back in the day, then your remote is hot whenever the ignition is on, when you turn your radio off and drive the amp is still on, wouldnt hurt anything, so to have better control add a toggle on remote, when the remote is from the radio it is on and off with the radio, then your hu has a sub control section that also has a sub on and off, so tha toggle isnt a must, but it is useful.:smoke: |
also when i was about 18, i had a really hot car, meaning i always got fckd with, there was a couple times i was pulled over bcause they heard loud music, i turned off the toggle and my subs didnt play, i would then tell the truth and say, the bass wasnt mine they dont have power!
found a line-out converter that hooks to your 12v constant but only sends signal to turn on the amp when the sound travels through the speakers it works perfect now if and when i decide to change my head unit all wires are there no more tearing truck apart no toggles or fuse box mess
