2 Channel Bridged
2 Channel Bridged
I've got a quick question that hopefully someone can help me out.
My 16 yr old nephew just bought 2 -15" RF Punch 1 subs for his 1st system. He is looking for a decent amp for under $200. Which this may be hard to find, but he's on a very tight budget.
He came across an Audiobahn A4002 2-channel amp for $199. If I recall correctly, I believe if it's bridged, it say's it'll push 400watts. The subs are rated up to 200watts rms.
Would this amp work, if bridged? If not, what would you suggest for under $200.
Like I said, this is his 1st system going in his 1st car and not alot of money
Here i found the subs http://www.rockfordfosgate.com/produ...punch_grid.asp
The only configurations are 4 and 8 single voice coil subs, so im guessing your friend has the 4ohm svc's.
So the overall independence for both of those subs wired together would be at 2ohms into the amp.
So you need a 400 watt rms x1 @ 2ohms or possibly use a 2 channel amp and wire the subs seperately so that wold be 200 watt rms x 2 @ 4ohms like this amp http://www.woofersetc.com/product.as...8&1=349&3=2688
But i would go with an amp more like this one http://www.woofersetc.com/product.as...2&1=363&3=2167 and MTX is usually known for sligtly underrating their amps so that would fit in with those subs wired at 2 ohms
