F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2015 - 2019 F-150 (https://www.f150online.com/forums/2015-2019-f-150-136/)
-   -   Front passenger floor is collecting water (https://www.f150online.com/forums/2015-2019-f-150/519834-front-passenger-floor-collecting-water.html)
EdO 12-02-2018 08:13 AM
2015 F150 Platinum
serotta 12-02-2018 09:24 AM
my 2017 Platinum was collecting water mostly near the A pillar at the carpet. I have a sunroof. It had a crimped drain tube on that side from the factory. Dealer pulled the molding and replaced the drain tube. Carpet dried out and hasn't leaked again.
Friend has a 2016 Platinum with same issue. They roof rail indentation was leaking at the seam on the passenger side. He got some color coded seal/caulk and ran a bead all along the seam. Problem solved.
gDMJoe 12-05-2018 01:56 PM
This is the 2009 - 2014 F-150 sectior of the forum.
Your posts are more appropriate for 2015 - 2019 F-150
crazynip 12-05-2018 10:04 PM
This is a problem with all the current trucks. There's these little drain holes at the bottom of the doors that get plugged up and you have to clean them. Kind of lame, but an easy fix. Both my rear doors do it occasionally.
glc 12-05-2018 11:38 PM
Post reported, mods have moved it.
© 2019 MH Sub I, LLC dba Internet Brands
