Trailer wiring harness/adapter? Is the truck supposed to come with it?
Old 08-07-2015, 01:07 PM
crazynip's Avatar
2015 F150 with trailer tow package
There is no adapter anywhere in the truck, I called the dealer and they said it's supposed to be in the glove box. It's not. And they are not being terribly helpful. Supposed to call me back in a bit...
If I have to buy one of these things, where would you recommend? And are they a fairly common part or unique to F150's? My 2005 just had the old style 4 pin flat trailer connector on the bumper, probably because I did not have the tow package or factory hitch.
Old 08-07-2015, 01:08 PM
crazynip's Avatar
One more question, will an adapter from a 2002 F150 work on it?
Old 08-07-2015, 03:24 PM
JackandJanet's Avatar
Crazy, what "adapter" are you asking about? If you have the tow package, I believe you have an integrated brake controller and you should have both the 4-pin and 7-pin plugs at the back, and, the hitch receiver.
Supposedly, in your glove box you will have a 30 Amp trailer battery charging fuse and you may have a relay for that purpose too - I did.
But there's no other "adapter" I'm aware of for towing. The only adapter I know about is one to add a 3rd party brake controller, which you should not need.
- Jack
Old 08-07-2015, 03:48 PM
crazynip's Avatar
I did not have anything in the glove box but 2 screws in a plastic baggy and the owners manual pouch...
I am talking about the round plastic 7 pin plug thingy... which converts down to the standard 4 pin trailer plug
Old 08-07-2015, 04:08 PM
fordmantpw's Avatar
If that is what you are looking for, one from a 2002 would fit.
However, in the back, you should have a connector for a 4 pin and a 7 pin, negating the need for the adapter. Have you checked that?
Old 08-07-2015, 08:04 PM
Crazy, look UNDER the bumper, to the left of the hitch receiver. I think they will both have weather covers over them.
- Jack
Old 08-10-2015, 09:58 PM
Hereford F150's Avatar
Our 2013 has both the round and the flat plugin on the left side under the bumper near the receiver.
Old 08-10-2015, 10:25 PM
bigmike0091's Avatar
on the 2015's they are by the license plate.. both 4 and 7
Old 08-17-2015, 07:07 PM
jr105's Avatar
I have a '15 with the trailer package with the 2 covered connectors next to the license plate, but I did have a trailer adapter in my glove box. The part # on the bag is FL3T 15A416-AA, but I don't know what it's for.
It has a squarish gray connector with 4 wires about a foot long labeled as follows.
Whole wire bundle - Labeled Instrument Panel Feed Bundle
Blue wire - Labeled To Trailer Electric
Violet wire - Labeled Stop Lamp
Blue/Black wire - Ground
Blue/Violet wire - Labeled Feed from Battery
I also had a second bag FL3T 15A562-AB Rear Video Camera Wiring Protective Cap.
Old 08-17-2015, 08:48 PM
jr105's Avatar
In looking into this further it looks like the adapter cable is to hook up a brake controller and the protective cap is used when the tailgate is removed to protect the camera connector.
Old 08-23-2015, 07:37 PM
My battery charging circuit is dead
my 2015 F 150 with trailer towing package was putting out power to the trailer battery circuit(it also powers my power tongue jack). It is now dead. I can not find anywhere which relay is it in the distribution box. What number is it?
Old 08-24-2015, 12:08 AM
Look in the Power Distribution Box section of your Owner's Manual. It will list it in the diagram there.
- Jack
Old 08-24-2015, 09:03 AM
That is why I'm asking. I looked in my manual and it does not state which fuse/breaker is for the power to charge the trailer battery. That is why I'm asking.
Old 08-24-2015, 10:53 AM
I owe you an apology, which I'm giving. You're right. I just spent a long time studying a Power Distribution Box diagram in an online version or the 2015 Owner's Manual. There is nothing there for the +12V Trailer Battery Feed. (Nothing in the "in-vehicle" fuse box either).
So, it's normally a 30A fuse, and my 2014 truck also has a relay for that purpose. The only 30A fuse whose purpose is not clear to me is #54, a "Voltage Quality Module". I'd start there, and if it's not the one, pull and check every 30A fuse. If you see anything in a "Not Used" slot, I'd pull and check that too, since the trailer battery fuse and relay are generally not installed at the factory.
Good luck. I looked in both a "first" and "third" printing of the manual, and neither one has the needed information. It really bugs me when the documentation does not keep up with the product.
- Jack
Old 08-24-2015, 04:01 PM
This is a connector for installing an aftermarket brake controller.
This is for covering the video cable on the truck if you remove the tailgate
Quick Reply: Trailer wiring harness/adapter? Is the truck supposed to come with it?
