List of TSB's and recalls
Old 01-14-2016, 01:12 AM
Mpkav's Avatar
I found this on another forum. I thought it might be good info to share!
Technical Service Bulletins:
TSB 15-0040
http://www.f150forum.com/attachments...tsb15-0040.pdf
FORD: 2015 F-150 – 3.5L GTDI - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC P25B0 - BUILT ON OR BEFORE 3/6/2015
TSB 15-0041
http://www.f150forum.com/attachments...tsb15-0041.pdf
FORD: 2015 F-150 – COLUMN SHIFTER HIGH EFFORT OR ROUGHNESS - BUILT ON OR BEFORE 2/13/2015
TSB 15-0045
http://www.f150forum.com/attachments...tsb15-0045.pdf
FORD: 2015 F-150 – GLOVE COMPARTMENT CLOSES IMPROPERLY
TSB 15-0052
http://www.f150forum.com/attachments...tsb15-0052.pdf
FORD: 2015 F-150 – SUPERCAB/SUPERCREW CAB - FROZEN OR INOPERATIVE DOOR LATCH - BUILT ON OR BEFORE 3/25/2015
TSB 15-0072
http://www.f150forum.com/attachments...tsb15-0072.pdf
FORD: 2015 F150 – 3.5L ECOBOOST - MALFUNCTION INDICATOR LAMP (MIL) WITH DTCS P0060, P0161, P0157, P0054, P0137 AND/OR P0141
TSB 15-0073
http://www.f150forum.com/attachments...tsb15-0073.pdf
FORD: 2015 F-150 & Mustang - 5.0L DOHC ENGINES - COOLANT LEAK
TSB 15-0076
http://www.f150forum.com/attachments...tsb15-0076.pdf
FORD: 2015 F-150 - ORIGINAL FORD ACCESSORY TAILGATE LINER WARPED
TSB 15-0080
tsb15-0080.pdf
FORD: 2015 F-150 - SUPERCREW - REAR SEAT CENTER ARMREST DOES NOT STOW FLUSH WITH REAR SEAT BACK - BUILT ON OR BEFORE 4/27/2015
TSB 15-0081
http://www.f150forum.com/attachments...tsb15-0081.pdf
FORD: 2015 F-150 - WATER LEAK AT A-PILLAR OR AROUND WINDSHIELD - BUILT ON OR BEFORE 1/13/2015
TSB 15-0093
http://www.f150forum.com/attachments...tsb15-0093.pdf
FORD: 2015 F-150 - MULTI-CONTOUR SEAT - ADJUSTMENT OR MASSAGE FEATURE INOPERATIVE - SCMG AND/OR SCMH AIR PUMP CONTINUALLY RUNS - BUILT ON OR BEFORE 4/21/2015
TSB 15-0098
http://www.f150forum.com/attachments...tsb15-0098.pdf
FORD: 2015 F-150, 2013-2016 Fusion, LINCOLN: 2013-2015 MKZ, 2015 MKC - ONE OR MORE POWER WINDOWS - INTERMITTENTLY INOPERATIVE IN FREEZING TEMPERATURES
TSB 15-0102
http://www.f150forum.com/attachments...tsb15-0102.pdf
FORD: 2015 F-150 - ELECTRONIC PARKING BRAKE - PARKING BRAKE MALFUNCTION MESSAGE IN THE MESSAGE CENTER WITH DTC U3000 – BUILT ON OR BEFORE 2/21/2015
TSB 15-0115
http://www.f150forum.com/attachments...tsb15-0115.pdf
FORD: 2011 - 2015 F-150 – 2015 Expedition, Transit, LINCOLN: 2015 Navigator - 3.5L GTDI WITH DTCS P0234 AND/OR P0299 - DRIVABILITY SYMPTOMS
This article supersedes TSB 15-0107 to update the Service Procedure.
TSB 15-0131
http://www.f150forum.com/attachments...tsb15-0131.pdf
FORD: 2011-2015 F-150 - 3.5L GTDI - COLD START - TICKING/TAPPING OR RATTLE TYPE NOISE - BUILT ON OR BEFORE 5/29/2015
TSB 15-0140
TSB 15-0140.pdf
Superseded by TSB 15-0154
TSB 15-0142
TSB 15-0142.pdf
FORD: 2015 F-150 – Harsh or Firm 5-4 Downshift
TSB 15-0147
http://www.f150forum.com/attachments...tsb15-0147.pdf
FORD: 2015 F-150 – KING RANCH/PLATINUM/LARIAT - DRIVER'S SEAT CUSHION COVER LOOSE OR WRINKLED MATERIAL
TSB 15-0153
MYFORD TOUCH/MY LINCOLN TOUCH - VARIOUS FUNCTIONAL CONCERNS - BUILT ON 9/8/2015 AND THROUGH 9/26/2015
FORD: 2015 F-150 - Taurus, 2016 Explorer, F-250, F-Super Duty, Fusion & LINCOLN: 2015 MKS
TSB 15-0154
http://www.f150forum.com/attachments...tsb15-0154.pdf
FORD: 2015 F-150 – LARIAT/PLATINUM/KING RANCH - CLIMATE CONTROLLED SEATS - FRONT SEAT BACKRESTS LACK OF COOLING PERFORMANCE
The article supersedes 15-0140 to update the Title, Issue Statement and Service Procedure
Tsb 15-0171
http://www.f150forum.com/attachments...tsb15-0171.pdf
2.7l gtdi - mil illuminated with dtc p2450 - built on or before 10/5/2015
TSB 15-0182
http://www.f150forum.com/attachments...5-0182.pdf3.5L GTDI WITH DTCS P0234 AND/OR P0299 - DRIVABILITY SYMPTOMS - ENGINE BUILD DATE ON OR BEFORE 2/28/2015
(This TSB supersedes TSB 15-0115)
TSB 15-0183
http://www.f150forum.com/attachments...tsb15-0183.pdf
2.7L GTDI LEAKS ENGINE OIL – BUILT ON OR BEFORE 7/1/2015
TSB 15-0193
http://www.f150forum.com/attachments...0193.pdfAnalog
Speedometer Needle Sticking And/Or Incorrect Speed Indication - - Effective Dec 16 2015/ Built On Or Before 8/31/2015
Recalls:
Recall Number: 15V279000
Recall Date: 05/12/2015
RCONL-15V279-7467.pdf
Component: STEERING
Problem Summary: Ford Motor Company (Ford) is recalling certain model year 2015 Ford F-150 trucks manufactured March 19, 2015, to March 30, 2015. The affected vehicles may have been built with a steering upper intermediate shaft that was improperly riveted.
Consequence: If the intermediate shaft was improperly riveted, it could separate from the intermediate shaft flex coupling, resulting in a loss of steering control and increasing the risk of a vehicle crash.
What Owners Should Do: Ford will notify owners, and dealers will inspect the intermediate shaft and replace it, as necessary, free of charge. The recall began on May 22, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15S17.
Recall Number: 15V251000
Recall Date: 04/28/2015
RCONL-15V251-7642.pdf
Component: STRUCTURE: FRAME AND MEMBERS:UNDERBODY SHIELDS
Problem Summary: Ford Motor Company (Ford) is recalling certain model year 2015 Ford F-150 vehicles manufactured January 30, 2015, to January 31, 2015. The affected vehicles may have loose or missing underbody heat shields.
Consequence: A missing under body heat shield can lead to degradation or melting of the fuel or vapor lines, increasing the risk of a fire.
What Owners Should Do: Ford will notify owners, and dealers will inspect the vehicle for missing underbody heat shields and fasteners, and will install the missing components as required, free of charge. The recall began on May 13, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15S12.
Recall Number: TBD
Recall Date: 9/30/2015
Component Adaptive Cruise Control for Ford F-150
Ford is recalling some 37,000 2015 Ford F-150 pickup trucks for a potential issue with the adaptive cruise control. The company said that when passing "a large, heavily reflective truck," the radar in the adaptive cruise could incorrectly identify the truck as being in the F-150's lane of travel. The F-150 could then automatically apply the brakes until the adaptive cruise system no longer believes this to be the case. Ford said it received a report of one accident related to this issue. No injuries were reported. The recall affects certain 2015 Ford F-150 vehicles built at Dearborn Truck Plant, March 18, 2014 through Aug. 5, 2015, and at Kansas City Assembly Plant, Aug. 11, 2014 through Aug. 6, 2015. It includes 36,857 trucks in North America; including 33,481 in the U.S. Dealers will update the adaptive cruise software at no cost. Ford's number for this recall is 15S29.
Old 01-14-2016, 06:47 AM
stuck screw's Avatar
Thanks,
links don't work.
Old 01-14-2016, 07:02 AM
Mpkav's Avatar
Here's the link to the page.
http://www.f150forum.com/f118/2015-f...isting-316605/
Old 01-15-2016, 01:12 PM
OgRedd's Avatar
Nice list. Still nothing on those noisy panoramic, two panel sunroofs... - Og
Old 01-15-2016, 05:44 PM
Mpkav's Avatar
I thought the same! Hopefully there will be something soon. It looks like they are addressing the leather seat and frozen lock problem! I also have the warped bed liner so I will be making an appointment!
Old 10-02-2016, 06:15 PM
Cptrdr's Avatar
Spark Plug change
Did ford issue a new TSB changing the part number for the spark plug and the gap limits for the 2011 F150 3.5l ecoboost v6? I have a misfire issue on my truck. I have 76k Miles on the engine and knownitnis time to replace them. I have researched on line for the ford recommended plugs but have found that what ford is recommending and what people are posting is 2 different numbers. I know, always gonwith what the manufacturer says but I am just trying to make sure before I actually purchase the plugs.
Ford still says Motorctaft SP-528
several threads I have found state MOTORCRAFT SP-534 with a .028-.037 gap
Old 03-05-2020, 04:23 PM
I am an F-150 reporter for Torque News. I am always looking for F-150 news/info to write about. For example, today, I covered the daytime running light recall: https://www.torquenews.com/9539/ford...adlights-f-150
Old 03-07-2020, 10:18 AM
Good story Jimmy. Thank you.
Old 03-07-2020, 10:44 AM
Following up more, I wrote this more comprehensive story with all four of the 2020 F-150 recalls listed with some input from me too. https://www.torquenews.com/9539/some...-f-150-recalls
Old 03-14-2020, 11:51 AM
And here's a story on the frozen door locks. This one is interesting. Anyone have a truck part of this? https://www.torquenews.com/9539/some...ock-settlement
Old 04-07-2020, 01:08 PM
Another TSB for certain 10-speed transmission vehicles. https://www.torquenews.com/9539/anot...-transmissions
Old 07-16-2021, 11:02 AM
Rapid Red's Avatar
Doesn't look like any TSB's have been produced since 2016. At least according to this list. Wonder why.
