Biased Reporting?
Biased Reporting?
Is anyone else annoyed at the series of choices and the probable reasons behind them, that led the powers that be to crash test the new F150 months before the other truck manufacturers, and suddenly there is a new test included that has never been used before?
The SuperCrew passed with flying colors on all tests, but in the new one, the Super Cab didn't do as well, due to a part that is found only on the SuperCrew, but will now be added to all models for 2016.
So let me ask the question, with this info in hand, will the other manufacturers quietly make some running changes before submitting their trucks to testing? Then crow about their results in every ad?
Another fine test from the IIHS, a group that revels in coming up with new tests to cover outlier situations that only work in a vacuum.
This group's entire mission is to come up with new ways to raise your insurance rates in the name of safety. The "test" the F150 failed was a high speed, High offset collision. Or in the off chance a vehicle would be going fast and just barely clip a completely solid object. The IIHS says they will only test the most popular body style when several body styles are sold. But when they noticed the high volume and therefore tested SuperCrew had a brace the other trucks didn't have they wanted to test it too. Auto makers have been doing things like this for years to pass these silly, arbitrary tests. Toyota has been caught rigging tests for some time too.
The sooner the IIHS goes away the better our cars will be
It's not just Ford that designs cars to pass these absurd tests. A lot of cars have more structure on the drivers side because that's the only side the IIHS ever tests. They also base their entire safety assessment on a few tests that do not truly determine how safe a car is or how it acts in the real world. Look at the Government crash ratings and ignore the IIHS. The .gov tests actually account for a much broader and truer representation of a vehicle's safety.
The IIHS exists to raise insurance rates not to make cars safer.
When the vehicle you are interested in is being bad mouthed, it seems every media outlet you come across is pushing the story, but when a competing vehicle has some negative press, it seems as if it is pushed under the rug
The main thing I find sketchy is that the 2015 extended cabs from GM & Ram are not tested to correspond with the 2015 SuperCab. If you are looking to point out the discrepancies between cab configurations, don't give the other brands an advantage of fixing a previously undetected wrong (for fairness).
To be honest, every variation of base trim should be tested. Coupes, sedans & wagons/hatchback for cars and regular, extended & crew cabs for trucks. Both 2 door and 4 door Wrangler need to be evaluated separately. Regular and extended length SUVs also need separate testing (uplevels shouldn't have structural differences).
Actually they call it the "small overlap" crash test. But you are saying close to the same thing, just in a different way.
And it was at 40 mph, which to me is not "high speed".
IIHS bias in reporting and comparisons have now been confirmed by Mike Levine. Ram has some 'splaining to do after they claimed all Rams are designed equally.
The facts now are all Rams are not all designed equally and Ram only puts the blockers on some 2015 Rams.
IIHS will not test 2015 Rams for small overlap like they did with Ford. This gives Ram time to put the blockers on all 2016 Rams.
In fact IIHS was planning to test 2015 GMs and 2015 Rams but backed out.
