A/C Drain Issue
Have a question for you guys. I have a 2010 F-150 that seems to be missing some piece of the A/C drain? The condensation currently dribbles down the firewall and above the floor pan heat shield/insulation causing it to become saturated and sag. There is only a oddly shaped stub sticking out where the drain would be and no hose or fitting. Due to the odd shape of this piece, no hose can be fitted to it? Do all 2010's look like they have a set up like mine or is something missing? I'm concerned the condensation will cause the insulation to eventually fall off or catch on fire since it is resting on top of the catalytic converter? I tried putting some tape around the base of it to deflect the water but it does not help much.
2010 F-150 XLT 4.6L 3V V8 4x4 SuperCab 6.5' Box https://cimg5.ibsrv.net/gimg/www.f15...916dde990f.png |
